Code Red => .NET => Topic started by: Andrey Bushman on June 14, 2011, 10:47:31 AM
Hi.
From ObjectARX 2009:
public CommandMethodAttribute(
string groupName,
string globalName,
string localizedNameId,
CommandFlags flags,
Type contextMenuExtensionType,
string helpFileName,
string helpTopic
How can I use localizedNameId? I don't want use null. Give me code sample please...
From ObjectARX 2009: string localizedNameId - Input command localized name Id.
quote here (http://forums.autodesk.com/t5/NET/ContextMenuExtension/td-p/2377245):
The LocalizedNameId is the string resource identifier
of the localized name of the command. If provided,
the localized name of the command is obtained from
the resource, which can be stored in a locale-specific
satellite resource assembly.
"resource" - is it resx-file in MS VS 2010?
if I set string value (for example "cmd1") for localizedNameId directly then:
Command: netload
Cannot load assembly. Error details:
System.Resources.MissingManifestResourceException: Could not find any resources
appropriate for the specified culture or the neutral culture. Make sure
"LocalizationExample.Class1.resources" was correctly embedded or linked into
assembly "LocalizationExample" at compile time, or that all the satellite
assemblies required are loadable and fully signed.
at System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo
culture, Boolean createIfNotExists, Boolean tryParents)
at System.Resources.ResourceManager.GetString(String name, CultureInfo
culture)
at System.Resources.ResourceManager.GetString(String name)
at Autodesk.AutoCAD.Runtime.CommandClass.AddCommand(ICommandLineCallable ca,
MethodInfo mi)
at
Autodesk.AutoCAD.ApplicationServices.AutoCADApplicationHolder.Initialize(Assembl
y assembly)
at
Autodesk.AutoCAD.ApplicationServices.ExtensionLoader.ProcessAssembly(Assembly
assembly)
thank you.
Hi.
http://through-the-interface.typepad.com/through_the_interface/2007/03/getting_the_lis.html
Hi.
This link has what relation to my message? I need sample with localizedNameId.
Hi.
Sorry I do not speak English.
Do a search.
http://www.google.com/search?q=localizedNameId&btnG=%C2%BB&domains=through-the-interface.typepad.com&sitesearch=through-the-interface.typepad.com
Hi.
Do a search.
I always use Google before asking a question.
Do I understand that no one has experience in the localization team by setting localizedNameId? :cry:
There can be it will help with understanding of an essence of my problems (they are specified in code comments):
using System;
using System.Linq;
using System.Text;
using System.IO;
using System.Drawing;
using acad = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.AutoCAD.Windows;
* Windows XP SP3 x86
* AutoCAD 2009 SP3 Enu
* .Net Framework 3.5 SP1
* Microsoft Visual Studio 2010
namespace LocalizationExample {
public sealed class Class1 {
const string grName = "bush";
//It works successfully
const string helpFileName = @"Debug\help\ru-RU\MyHelp_ru-RU.chm";
const string helpTopic = "t2";
//With it couldn't understand (if to use this variable - I receive an error at NetLoad)
public const string locname = "cmd1";
[CommandMethod(grName, "cmd", /*locname - it was not possible to use, ObjectARX 2009
* doesn't contain an example of usage of this parameter (localizedNameId).*/
null, CommandFlags.Modal,
typeof(ExampleContextMenu), helpFileName, helpTopic)]
public void MyCommand() {
Editor ed = acad.DocumentManager.MdiActiveDocument.Editor;
ed.WriteMessage("Hello World \n");
ed.GetString("Print message");
/// <summary>
/// http://through-the-interface.typepad.com/through_the_interface/2008/11/displaying-a-co.html
/// </summary>
public sealed class ExampleContextMenu : ContextMenuExtension {
public ExampleContextMenu() {
this.Title = "Command context menu";//This text isn't displayed anywhere. Where it should appear?
MenuItem mi = new MenuItem("Item One");
//The specified file (Config.ico) exists! Why this icon isn't displayed?
Icon icon = new System.Drawing.Icon(@"D:\123\LocalizationExample\images\Config.ico");
mi.Icon = icon;
MenuItem smi = new MenuItem("Sub Item One");
smi.Enabled = false;
mi.MenuItems.Add(smi);
smi = new MenuItem("Sub Item 2 One");
smi.Checked = true;
this.MenuItems.Add(mi);
mi = new MenuItem("Item Two");
mi.Visible = false;
Context menu screen: https://docs.google.com/leaf?id=0B7H_2Cq9tBXdZmEyNzQ2ODQtMzNlMi00OTA5LWIyZjgtZThlNzg5MmQ1YTc2&hl=ru
It works for me.
The pic is supposed to be your Avatar but is hard to see the cat.
The icon must be 16x16.
The code is straight from the link in your code from Through the interface http://through-the-interface.typepad.com/through_the_interface/2008/11/displaying-a-co.html
Just added the icon part
public class MyCommands
public class MyContextMenu : ContextMenuExtension
public MyContextMenu()
Icon icon = new Icon(@"C:\Users\Jeff\Pictures\ICO\avatar_6108.ico");
mi.Icon = icon;
mi.Click += new EventHandler(MyCommands.OnClick);
smi.Click += new EventHandler(MyCommands.OnClick);
this.MenuItems.Add(smi);
[CommandMethod("mygroup", "mycmd", null, CommandFlags.Modal, typeof(MyContextMenu))]
public static void MyCommand()
ed.GetPoint("\nRight-click before selecting a point:");
static void OnClick(object sender, EventArgs e)
Editor ed =
ed.WriteMessage("\nA context menu item was selected.");
Yes, I know.
It works for me.
What version at you AutoCAD? I have AutoCAD 2009 SP1 x86.
p.s. With parameter localizedNameId I have understood (me Alexander Rivilis has helped).
2012
