Author Topic: "and" versus "if"  (Read 4155 times)
Peter2
"and" versus "if"
« on: November 22, 2013, 12:18:03 PM »
I found this code
(and (= f ".") (setq Dirs (cddr Dirs)))
(foreach n Dirs
Now there is no second condition, and so I wonder why it is not:
(if (= f ".") (setq Dirs (cddr Dirs)))
(foreach n Dirs
The only difference I see is that
- 'and' returns T or nil
- 'if' returns nil or the new value of 'Dirs'
but 'foreach' does not care about it ...
So what is the advantage of 'and' in this fragment?
Peter
BricsCAD V23
dgorsman
Re: "and" versus "if"
« Reply #1 on: November 22, 2013, 12:35:13 PM »
Not much, aside from being easier to extend if additional conditions are expected in the future.  Other than that, its more of a style choice.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
owenwengerd
« Reply #2 on: November 22, 2013, 01:12:30 PM »
In my opinion, (if) is better in this case because it is less likely to be misunderstood. However, I would write it more succinctly:
(foreach n (if (= f ".") (cddr Dirs) Dirs)
irneb
« Reply #3 on: November 22, 2013, 01:39:12 PM »
With you on that .... though ....
If you take Owen's post into account, a cond would probably sort out both scenarios. Easier to extend, yet still readable without special knowledge of how Lisp operates.
That's actually a peculiarity of AutoLisp. In all other Lisps (at last those I've used) there would be asolutely no difference in this case. The and would return the exact same thing as the if does.
Exactly. Any boolean test in Lisp (all types of Lisps) is a situation of: "Is it something else than nil? If so consider it true, else consider it false."
« Reply #4 on: November 22, 2013, 02:54:32 PM »
I use AND sometimes just because it keep all the code on one line when formatted.  ;D
Peter2
« Reply #5 on: November 22, 2013, 04:53:08 PM »
Thanks to all for the interesting comments. My 2 cents for flexibility: 'If' can be modified with 'else-code', 'and' not ...
Have a fine weekend!
Peter
BricsCAD V23
« Reply #6 on: November 22, 2013, 07:19:23 PM »
Ditto  8)
« Reply #7 on: November 22, 2013, 08:18:36 PM »
Where's John when you want a good argument regarding if, and, or, cond.
irneb
« Reply #8 on: November 23, 2013, 06:52:22 AM »
  :lmao: ... you could always go bonkers and make the code so obtuse as to mislead even yourself. E.g. what about converting each input into integers and then using logand on them?  :-P
irneb
« Reply #9 on: November 23, 2013, 07:02:49 AM »
Yes, that's a good point too. Yet another reason cond is more flexible (it can have multiple elses without needing to nest ifs).
irneb
« Reply #10 on: November 23, 2013, 07:12:02 AM »
(foreach n Dirs
Personally in your code example I'd simply remove the current directory "." and parent directory ".." a different way. But that's just me, I don't like relying on them always being the 1st 2 ... not that I've ever found them otherwise, but I've seen too many issues happen when relying on the order of a list. I'd have done something like this instead:
(foreach n (vl-remove "." (vl-remove ".." Dirs))
Edit: e.g. what if the list of dirs is sorted? Could you still rely on "." and ".." to be the 1st two in the list?
« Last Edit: November 23, 2013, 07:20:00 AM by irneb »
Peter2
« Reply #11 on: November 23, 2013, 08:34:51 AM »
a) yes, it's sorted.
b) ... rely on ..- I think yes, because Dirs is a list of subdirs (it's not my code ...)
Peter
BricsCAD V23
irneb
« Reply #12 on: November 24, 2013, 11:32:24 PM »
Well, in most cases "." would be at the start if you sort the list. It's supposed to be at the start on a raw list (as obtained from vl-directory-files). But if one of the sub-dirs start with a "strange" character (e.g. $ or any of those allowed with an ASCII code smaller than that of ".") it would get placed before the "." and ".." when sorted.
Peter2
« Reply #13 on: November 27, 2013, 02:02:47 PM »
.... But if one of the sub-dirs start with ...
Yes, thank you. That's an important argument.
Peter
BricsCAD V23
