Author Topic: Wblock Template  (Read 1542 times)
TJK44
Wblock Template
« on: January 10, 2014, 01:18:28 PM »
Is there a way to control which template AutoCAD uses when WBlocking?
Thanks,
-Ted
tedg
Re: Wblock Template
« Reply #1 on: January 13, 2014, 03:06:20 PM »
I don't think it works that way.
Because you are in an existing drawing, you are basically are copying whatever standards, active layouts etc. that you have selected to create a new drawing file.
So only the content you select goes into the new file along with whatever styles etc. that were current at the time.
I believe that's how it works.
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
