Are you creating 2 blocks from 1?I thought that WIPEOUT will be just enough, just it has to have as boudary 2 parallel polylines connected from bottom and top side... Block should remain untouched with same look...
Quote from: ribarm on November 28, 2023, 01:03:28 PMAre you creating 2 blocks from 1?I thought that WIPEOUT will be just enough, just it has to have as boudary 2 parallel polylines connected from bottom and top side... Block should remain untouched with same look...The original poster did not mean to dig out a strip in the middle.But a line divides the two parts
