CAD Forums => CAD General => Topic started by: Lupo76 on November 21, 2023, 01:11:21 AM
Hi everyone,
after defining a new parameter using the parameter manager, is it possible to insert it into a text?
I saw that this can be done inside a block using Fields>Object>Blockplaceholder but this way I can only use the parameters defined inside the block :-(
Instead, I would like to use a global user parameter.
To explain myself better, I attach a dwg file in which you can find the "USER_GLOBAL_PARAMETER" parameter that I would like to insert as text in the drawing.
Can you help me?
Thank you.
