Author Topic: line ends with gap and dot  (Read 3535 times)
confusedCADguy
« on: March 19, 2004, 05:24:07 PM »
Here's a good one to keep you busy this weekend.  Has anyone ever had a line appear to have a gap with a dot at the end?  Sort of like a dimension would have. Now when I say end I mean a line drawn from point ‘a’ to point ‘b’, point ‘b’ being where the gap & dot shows up.  The strange part is no matter how close you zoom the gap never gets any bigger. And, a majority of the time it doesn’t show up until you do a regen. When you use an osnap such as endpoint it locks on to the ‘dot’ at the end of the line.  I’ve checked everything.  It’s a normal line, no ‘z’ coordinate.  I can’t really figure it out.  Any ideas?
daron
« Reply #1 on: March 19, 2004, 05:51:18 PM »
What's the layer's and/or objects (i.e. line's) linetype?
confusedCADguy
« Reply #2 on: March 19, 2004, 05:53:09 PM »
It didn't make a difference which layer it was on.  The linetype is continuous but I didn't check to see if it happened with other linetypes.
« Reply #3 on: March 19, 2004, 09:46:50 PM »
Sounds like a video card problem....
« Reply #4 on: March 20, 2004, 07:25:00 PM »
Are you using any 3rd party software?
confusedCADguy
« Reply #5 on: March 22, 2004, 03:59:53 PM »
No 3rd party software, just plain vanilla 2002 with enablers loaded for arch desktop
« Reply #6 on: March 22, 2004, 04:23:46 PM »
Try copying some of these lines and paste them into a new drawing. See if you have the same results or any lt definiitions are brought with it.
Ron
