Author Topic: Speed up this line draw routine ..  (Read 4555 times)
« on: June 22, 2010, 12:25:06 AM »
Not really a challenge , but if you feel inclined .. :)
Anyone see a way to speed this routine up, based on the data provided ??
Essentially it's taking a point list and 'connecting the dots' with lines in the current UCS.
I tried an ActiveX solution but it's about 4.5 times slower.
Haven't looked at ARX or C# yet ....
DATA :
(setq vertexList1 (list (setq sp (list 0. 0. 0.))
                        (list 200. 0. 0.)
                        (list 200. 100. 0.)
                        (list 0. 100. 0.)
                        sp
      layerName   (getvar "CLAYER")
ROUTINE:
(defun test13 (vertexList layerName / TranslatedList DXF210)
;; Codehimbelonga kdub 2010.06.22
  (setq TranslatedList (mapcar '(lambda (x) (trans x acucs acworld)) vertexList)
        DXF210         (trans '(0 0 1) 1 0 T)
  (foreach ptPair (mapcar (function (lambda (a b) (list a b)))
                          TranslatedList
                          (cdr TranslatedList)
    (entmakex (list '(0 . "LINE")
                    '(100 . "AcDbLine")
                    (cons 8 layerName)
                    (cons 10 (car ptPair))
                    (cons 11 (cadr ptPair))
                    (cons 210 DXF210)
SOME OPTIONS :
(defun kdub:drawOneLineEn (sp ep la /)
                  '(100 . "AcDbLine")
                  (cons 8 la)
                  (cons 10 (trans sp acucs acworld))
                  (cons 11 (trans ep acucs acworld))
                  (cons 210 (trans '(0 0 1) 1 0 T))
(defun test12 (vertexList layerName /)
                          vertexList
                          (cdr vertexList)
    (kdub:drawOneLineEn (car ptPair) (cadr ptPair) layerName)
Some TEST Results :
Benchmarking [M.P. 2005 < revised kdub 2005>] ...............
Elapsed milliseconds for 4096 iteration(s)/ relative Timing :
    (TEST12 VERTEXLIST1 LAYERNAME).....1015 / 1.0150 <slowest>
    (TEST13 VERTEXLIST1 LAYERNAME).....1000 / 1.0000 <fastest>
« Last Edit: June 22, 2010, 12:42:01 AM by Kerry Brown »
Re: Speed up this line draw routine ..
« Reply #1 on: June 22, 2010, 12:38:53 AM »
It MAY be faster to draw a LWPolyLine and explode it  :-)
;;;   (setq vertexList (list (list 0. 0. 0.)
;;;                          (list 200. 0. 0.)
;;;                          (list 200. 100. 0.)
;;;                          (list 0. 100. 0.)
;;;         layerName  (getvar "CLAYER")
;;;   (kbub:drawEnPlineInUCS vertexList layerName 1)
;; vertexList points expressed in Current UCS
(defun kbub:drawEnPlineInUCS (vertexList layerName putClosed / DXF210 elev)
  (setq DXF210 (trans '(0 0 1) 1 0 T))
  (entmakex
    (append (list '(0 . "LWPOLYLINE")
                  '(100 . "AcDbEntity")
                  '(100 . "AcDbPolyline")
                  (cons 90 (length vertexList))
                  (cons 70 putClosed)        ; 1 closed : 0 open
                  (cons 8 layerName)
                  (cons 38 (caddr (trans (car vertexList) 1 DXF210)))
                  (cons 210 DXF210)
            (mapcar '(lambda (pt) (cons 10 (trans pt 1 DXF210))) vertexList)
Benchmarking [M.P. 2005 < revised kdub 2005>] ................
Elapsed milliseconds for 8192 iteration(s)/ relative Timing :
    (TEST12 VERTEXLIST1 LAYERNAME)...............2047 / 1.9257 <slowest>
    (TEST13 VERTEXLIST1 LAYERNAME)...............2016 / 1.8965
    (KBUB:DRAWENPLINEINUCS VERTEXLIST LA...).....1063 / 1.0000 <fastest>
« Reply #2 on: June 22, 2010, 12:49:20 AM »
just a note on this ;
The output is different to MP's original routine.
The fastest expression has been given a index of 1.
Subsequent expressions are shown with an index proportional to the time taken.
ie in this case Test12 takes 1.92 times longer to run than kbub:drawEnPlineInUCS.
Hope this doesn't cause confusion.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #3 on: June 22, 2010, 05:07:22 AM »
I also could not draw a lot of lines faster than explode polyline!  :-)
my test (acad 2008 sp2):
 (entmakex (append (list '(0 . "LWPOLYLINE")
                         (cons 8 layerName)
                         (cons 210 DXF210)
                   ) ;_  list
           ) ;_  append
 ) ;_  entmakex
) ;_  defun
(defun test_5 (l n c)
 (if (setq l (kbub:drawEnPlineInUCS l n c))
  (progn (vla-explode (vlax-ename->vla-object l)) (entdel l))
 ) ;_  if
) ;_  defun
                 '(100 . "AcDbLine")
                 (cons 8 la)
           ) ;_  list
 ) ;_  entmakex
) ;_  defun
 (foreach ptPair
          (mapcar (function (lambda (a b) (list a b))) vertexList (cdr vertexList))
 ) ;_  foreach
) ;_  defun
(defun test_6 ( l n /)
                                    '(100 . "AcDbLine")
                                    (cons 8 n)
                                    (cons 10 (trans a acucs acworld))
                                    (cons 11 (trans b acucs acworld))
                                    (cons 210 (trans '(0 0 1) acucs acworld T))
                              ) ;_  list
                    ) ;_  entmakex
                   ) ;_  lambda
         ) ;_  function
         l
         (cdr l)
 ) ;_  mapcar
) ;_  defun
(defun test_7 (l n / v)
 (setq l (mapcar '(lambda (a) (trans a 1 0)) l)
       n (cons 8 n)
       v (cons 210 (trans '(0 0 1) 1 0 T))
 ) ;_  setq
 (mapcar
  (function (lambda (a b) (entmakex (list '(0 . "LINE") n (cons 10 a) (cons 11 b) v))))
  l
  (cdr l)
 ) ;_  mapcar
) ;_  defun
 (setq l '((0 0 0))
       n (getvar "CLAYER")
       c 1
 ) ;_  setq
 (mapcar
  (function (lambda (a) (repeat 1 (setq l (cons (mapcar (function +) a (car l)) l)))))
  '((1 0 0) (0 1 0) (-1 0 0) (0 -1 0))
 ) ;_  mapcar
) ;_  progn
(BenchMark '((test12 l n) (test_5 l n c)(test_6 l n)(test_7 l n)))
Benchmarking ..............Elapsed milliseconds / relative speed for 2048 iteration(s):
    (TEST_6 L N).......1078 / 1.62 <fastest>
    (TEST_7 L N).......1078 / 1.62
    (TEST12 L N).......1125 / 1.56
    (TEST_5 L N C).....1750 / 1.00 <slowest>
 (setq l '((0 0 0))
       n (getvar "CLAYER")
       c 1
 ) ;_  setq
 (mapcar
  (function (lambda (a) (repeat 10 (setq l (cons (mapcar (function +) a (car l)) l)))))
 ) ;_  mapcar
) ;_  progn
Benchmarking ............Elapsed milliseconds / relative speed for 512 iteration(s):
    (TEST_5 L N C).....1672 / 1.38 <fastest>
    (TEST_7 L N).......2110 / 1.10
    (TEST_6 L N).......2234 / 1.04
    (TEST12 L N).......2313 / 1.00 <slowest>
 (setq l '((0 0 0))
       n (getvar "CLAYER")
       c 1
 ) ;_  setq
 (mapcar
  (function (lambda (a) (repeat 100 (setq l (cons (mapcar (function +) a (car l)) l)))))
 ) ;_  mapcar
) ;_  progn
(BenchMark '((test12 l n) (test_5 l n c) (test_6 l n) (test_7 l n)))
Benchmarking ..........Elapsed milliseconds / relative speed for 128 iteration(s):
    (TEST_5 L N C).....2093 / 2.12 <fastest>
    (TEST_7 L N).......3890 / 1.14
    (TEST_6 L N).......4203 / 1.06
    (TEST12 L N).......4438 / 1.00 <slowest>
« Last Edit: June 22, 2010, 05:10:49 AM by ElpanovEvgeniy »
« Reply #4 on: June 22, 2010, 06:05:47 AM »
Perhaps:
(defun LM_poly ( l / n p )
  (setq n (trans '(0. 0. 1.) 1 0 t)
        p (list (cons 10 (trans (car l) 1 n))))
  (while (setq l (cdr l))
    (setq p (cons (cons 10 (trans (car l) 1 n)) p))
                           (cons 90 (length p))
                           (cons 70 1)
                           (cons 38 (cadddr (car p)))
                           (cons 210 n)
                     p
(defun LM_test ( l / p )
  (if (setq p (LM_poly l))
      (vla-Explode (vlax-ename->vla-object p))
      (entdel p)
« Reply #5 on: June 22, 2010, 06:19:59 AM »
Perhaps:
Yes, that's been covered Lee :-D
« Reply #6 on: June 22, 2010, 06:22:21 AM »
I thought that the way the list was constructed may be faster is all - I did read the thread...  :roll:
« Reply #7 on: June 22, 2010, 06:24:23 AM »
I can't see a while, 2 con's and 2 setq's being faster ... but would be interested in seeing a test if you think it may be faster ..
I'm at home with a bottle of red at the moment, don't feel like writing code :)
pkohut
« Reply #8 on: June 22, 2010, 06:32:50 AM »
Doesn't trans and entmake(x) go through the ADS interface?  If they do then that's a bottleneck there.
« Reply #9 on: June 22, 2010, 06:36:26 AM »
entmake is about 4.5 times faster than ActiveX Paul.
and the option to trans is writing our own translator .. :)
The code I posted is actually pretty fast, just looking for alternatives.
pkohut
« Reply #10 on: June 22, 2010, 06:41:54 AM »
Didn't know that about the activex, was thinking...um wasn't really.. :-D
« Reply #11 on: June 22, 2010, 07:01:09 AM »
Kerry, in your test13 you used this
(setq TranslatedList (mapcar '(lambda (x)but this should be faster
(setq TranslatedList (mapcar (function (lambda (x)
and WHILE is faster than foreach  :-)
Joe Burke
« Reply #12 on: June 22, 2010, 07:02:16 AM »
Hi Kerry,
Just curious. Is this, "entmake is about 4.5 times faster than ActiveX" a blanket statement or does it just apply to this topic?
My experience/testing with creating objects with entmake vs ActiveX indicates they are in general about the same speedwise. Of course I might be wrong.
« Reply #13 on: June 22, 2010, 07:08:27 AM »
May show some improvement, no time to test this morning.  Later 8-)
(defun test13cab (vertexList layerName / TranslatedList DXF210)
  (setq TranslatedList (mapcar (function (lambda (x) (trans x acucs acworld))) vertexList)
  (setq PairLst (mapcar (function (lambda (a b) (list a b)))
                          TranslatedList
   (while (setq ptPair  (car PaitLst))
     (setq PairLst (cdr PairLst))
                    '(100 . "AcDbLine")
                    (cons 8 layerName)
                    (cons 210 DXF210)
« Reply #14 on: June 22, 2010, 07:52:16 AM »
Hi Kerry,
Just to this Joe ... don't have the code handy but my tests ranged between 3.8 and 4.5 times
... perhaps the code could have been optimised but didn't seem worth it.
