Author Topic: PInvoke acdbEntUpd  (Read 16317 times)
Re: PInvoke acdbEntUpd
« Reply #15 on: June 12, 2010, 08:49:01 PM »
Thanks Luis, I'll have a look shortly
Do you know why an array of longs is used as a parameter ??
because of this:
typedef long ads_name[2];  (under arxdef.chm a2008 and adsdef.h)
ahhh .. makes sense  :-)
LE3
« Reply #16 on: June 12, 2010, 08:52:52 PM »
I started to use a home made PInvoke class (and for my own arx exported functions), and depending on the needs I add that on my new projects.
Sorry, I know I use that, but was easy for me to do the quick test here.
Thanks Luis
One more:
Why are you using PInvoke.xxxxx ??
Did you have those DLLImport definitions in a  PInvoke class at one stage ??
LE3
« Reply #17 on: June 12, 2010, 08:59:26 PM »
And do not why this info is not on the latest arxref help (at least per my findings in the ARX sdk 2010)
« Reply #18 on: June 12, 2010, 08:59:40 PM »
Thanks, I do the same thing .. API's in their own class.
thought is would be the case :-)
pkohut
« Reply #19 on: June 12, 2010, 09:23:57 PM »
if ObjectId in the .Net world == AcDbObjectId in the C++ world, then ads_name != ObjectId.
You have to use the .Net equivalent of these C++ API's
acdbGetObjectId(AcDbObjectId & objId, ads_name objName)  or
acdbGetAdsName(ads_name & objName, AcDbObjectId objId) to go the other way around.
Under the covers ads_name is 2 32 bit longs in 32 bit Autocad and 2 64 bit longs in 64 bit acad.
Up to 2007,
typedef long     ads_name[2];2008+,
#ifndef _WIN64
typedef __w64 long ads_name[2];
typedef __w64 long *ads_namep;
#else
typedef __int64 ads_name[2];
typedef __int64 *ads_namep;
#endif
(mental juggling here, about how TT's code would work)
But that really doesn't matter since the 128 bit ads_name of .Net will comfortably fit the 64 bit ads_name of 32 bit Acad, so they are compatible.
« Reply #20 on: June 12, 2010, 09:26:25 PM »
because of this:
I don't have a arxdef.chm ; assume you mean arxref.chm, which I was using
I'm using AC2011.
The ads_name is defined in adsdef.h as you say,
and described in the arxdev.chm ... which I hadn't looked at  :oops:
Thanks Luis.
« Reply #21 on: June 12, 2010, 09:31:58 PM »
Thanks Paul
That clarifies jgr's comment and confirms the translation.
I really mucked up the array of longs for ads_name  :oops:
Thanks for posting.
pkohut
« Reply #22 on: June 12, 2010, 09:32:40 PM »
Type "ads_name" in arxdev.chm and check out "about" and "exchanging with AcDbObjectId's".
LE3
« Reply #23 on: June 12, 2010, 09:40:13 PM »
Yikes... need another glasses :ugly:
Yes, did not look into arxdev, normally I always use arxref...
I'm using AC2011.
Thanks Luis.
LE3
« Reply #24 on: June 12, 2010, 09:42:40 PM »
Which one?
« Reply #25 on: June 12, 2010, 10:16:06 PM »
Thanks guys .. it's been an illuminating couple of hours  :-)
« Reply #26 on: June 13, 2010, 05:38:40 AM »
Quote from: Tony T adng
I think this is what you would use:
static extern int acdbEntUpd( out Int64 ename );
Something else to test :)
LE3
« Reply #27 on: June 13, 2010, 11:37:03 AM »
Did you tried Kerry?
Don't understand the out in there... the arx signature does not return the ads_name.... now I am confuse.
Now, I am going for my first coffee...
It works.
Another trick of Tony's bag of tricks... good
« Last Edit: June 13, 2010, 11:47:42 AM by LE3 »
« Reply #28 on: June 13, 2010, 11:01:55 PM »
At the moment I'm quite happy with this test
... that may change , of course :)
[assembly: CommandClass(typeof(KdubTesting.TestCommands))]
namespace KdubTesting
    // CodeHimBelongaKdub Jun 2008
    public partial class TestCommands
        const string ACAD_EXE = "Acad.exe";
        const short RTNORM = 5100;
        const short RTERROR = -5001;
        // ARX signature:
        // Acad::ErrorStatus acdbGetAdsName(ads_name& objName, AcDbObjectId objId);
        [DllImport("acdb18.dll", CallingConvention = CallingConvention.Cdecl,
            EntryPoint = "?acdbGetAdsName@@YA?AW4ErrorStatus@Acad@@AAY01JVAcDbObjectId@@@Z")]
        public static extern ErrorStatus acdbGetAdsName(out long adsName, ObjectId id);
        * Parameters
        *  ads_name& objName    Output ads_name
        *  AcDbObjectId objId   Input object ID
        * This function fills in objName with the ads_name that
        * corresponds to the objId object ID.
        * Returns Acad::eOk if successful.
        * If objId is 0, then Acad::eNullObjectId is returned.
        // ARX signature:
        // int acdbEntUpd( const ads_name ent);
        [DllImport(ACAD_EXE, CallingConvention = CallingConvention.Cdecl,
            EntryPoint = "acdbEntUpd")]
        public static extern int acdbEntUpd(out long adsName);
        * If acdbEntUpd() succeeds, it returns RTNORM  ( 5100 )
        * otherwise,                it returns RTERROR.(-5001 )
        * When acdbEntUpd() fails, it sets the system variable ERRNO to a value
        * that indicates the reason for the failure.
        [CommandMethod("Test0614a")]
        static public void Test0614a_acdbEntUpd_withInt64()
            Document doc = AcadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            PromptEntityResult per = ed.GetEntity("\nSelect object: ");
            if(per.Status != PromptStatus.OK)
                ed.WriteMessage("\n Nothing Selected");
                return;
            ObjectId id = per.ObjectId;
            long adsName ;
            ErrorStatus es = acdbGetAdsName(out adsName, id);
            if(es != ErrorStatus.OK)
                System.Windows.Forms.MessageBox.Show(
                    String.Format("ErrorStatus is: {0} \nCancelling Routine.", es),
                    "acdbGetAdsName ErrorStatus failure");
                return;
            int api_Result = acdbEntUpd(out adsName);
            if(api_Result != RTNORM)
                   String.Format("ERRNO is : {0} \nCancelling Routine.",
                   AcadApp.GetSystemVariable("ERRNO")),
                   "acdbEntUpd api_Result failure");
                return;
            ed.WriteMessage("\n ObjectId is {0} ", id);
            ed.WriteMessage("\n adsName is {0} ", adsName);
            ed.WriteMessage("\n api acdbEntUpd_Result is {0} ", api_Result);
            ed.WriteMessage("\n System variable ERRNO  is {0} ",
                         AcadApp.GetSystemVariable("ERRNO"));
« Reply #29 on: June 13, 2010, 11:10:50 PM »
... however, something like this may be a little more practical.
I'd be happy to have someone seriously test it.
see file attached for includes.
        // ARX signature:
        * Parameters
        // ARX signature:
        [CommandMethod("Test0614b")]
        static public void Test0614b_acdbEntUpd_withBoolTestMethod()
                return;
            if( EntityUpdate(id))
                System.Windows.Forms.MessageBox.Show( "Entity Updates sucessfully", "Test0614b");
            else
                System.Windows.Forms.MessageBox.Show( "It hit the fan", "Test0614b");
        public static bool EntityUpdate(ObjectId id)
            long adsName;
            if(acdbGetAdsName(out adsName, id) != ErrorStatus.OK)
                return false;
            return (acdbEntUpd(out adsName) == RTNORM);
References
//AcCui :
//acdbmgd :
//acdbmgdbrep :
//AcDx :
//acmgd :
//AcMr :
//AcTcMgd :
//AcWindows :
//AdWindows :
//System :
//System.Core :
//System.Data :
//System.Windows.Forms :
//System.Xml&comref:
//Autodesk.AutoCAD.Interop
//Autodesk.AutoCAD.Interop.Common
//stdole
//mscorlib
