Author Topic: Lisp to Swap textstring between 2 Blocks, Not Working  (Read 3208 times)
HasanCAD
« on: January 26, 2011, 09:34:54 AM »
Please help
This lisp not working
(defun c:StSwap (/ doc spc)
  (defun *error* ( msg ) (and doc (_EndUndo doc)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ))
  (defun _StartUndo ( doc ) (_EndUndo doc) (vla-StartUndoMark doc))
  (defun _EndUndo ( doc ) (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-EndUndoMark doc)))
  (defun DocActv (/ doc spc ) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (setq spc (if (or (eq AcModelSpace (vla-get-ActiveSpace doc)) (eq :vlax-true   (vla-get-MSpace doc))) (vla-get-ModelSpace doc) (vla-get-PaperSpace doc))))
  (setq ATT1 (car (nentsel "\nSelect attribute1: ")))
  (SETQ ATT1VL (vlax-ename->vla-object ATT1))
  (SETQ ATT1STR (VLA-GET-TEXTSTRING ATT1VL))
  (setq ATT2 (car (nentsel "\nSelect attribute2: ")))
  (SETQ ATT2VL (vlax-ename->vla-object ATT2))
  (SETQ ATT2STR (vla-put-TextString doc ATT2VL))
Re: Lisp to Swap textstring between 2 Blocks, Not Working
« Reply #2 on: January 26, 2011, 11:35:01 AM »
This will cause your error - you are trying to modify a non-existent TextString property of the Document Object.
Better perhaps:
(vla-put-TextString ATT2VL ATT1STR)
Tharwat
  • Hypersensitive
« Reply #3 on: January 26, 2011, 11:50:00 AM »
Please help
What is the goal of that routine ?
HasanCAD
« Reply #4 on: January 27, 2011, 05:02:00 AM »
Better perhaps:
Working  :-)
HasanCAD
« Reply #5 on: March 30, 2011, 07:00:41 PM »
Is there a wy to code this lisp in a better way
(defun c:SX (/ doc spc)
  (defun LM:SetAttributeValue ( block tag value )
  ;; © Lee Mac 2010 - with some change by HasanCAD
  (vl-some (function (lambda ( attrib ) (if (eq tag (vla-get-TagString attrib)) (progn (vla-put-TextString attrib value) value)))) (vlax-invoke block 'GetAttributes)))
  (defun LM:GetAttributestxt ( block )
  (mapcar (function (lambda ( attrib ) (vla-get-TextString attrib))) (vlax-invoke block 'GetAttributes)))
(defun LM:GetAttributestag ( block )
  (mapcar (function (lambda ( attrib ) (vla-get-TagString attrib))) (vlax-invoke block 'GetAttributes)))
  (while
    (setq stVLs (VLA-GET-TEXTSTRING
  (vlax-ename->vla-object (car (nentsel "\nSelect AxisNo: ")))))
    (if (setq ss (ssget '((0 . "INSERT") (66 . 1))))
(setq blk (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
(setq blktag (nth 0 (LM:GetAttributestag blk)))
(setq blktxt (nth 0 (LM:GetAttributestxt blk)))
(setq BlkValue (strcat stVLs "-" blkTxt))
(LM:SetAttributeValue blk blktag BlkValue)
chlh_jd
« Reply #6 on: April 04, 2011, 10:38:30 PM »
hi all , to copy from block , I use this
;;; Nentsel
;;; function : to nentsel a entity In situ
;;; arg      : string to princ in command-line
;;; return   : a list ( ename point is-of-block? )
;;; Note     : if the ename is of a block , the routine copy a
;;;             similar entity , so you must entdel it later .
;;; by GSLS(SS)
(defun ss-Nentsel (msg / en en1 pt mat ins mat ent)
  (setq en (Nentsel msg))
  (if (= (length en) 4)
      (setq en1 (car en)
    pt (cadr en)
    mat (caddr en)
    ins (last mat)
    mat (reverse (cdr (reverse mat)))
    mat (append
  (mapcar '(lambda (x y)
     (append x (list y))
  mat
  ins
  '((0. 0. 0. 1.))
    ent (entget en1 '("*"))
    ent (vl-remove (assoc -1 ent) ent)
    en1 (entmakex ent)
      (if en1
  (setq obj (vlax-ename->vla-object en1))
  (vla-TransformBy obj (vlax-tmatrix mat))
  (setq en1 (vlax-vla-object->ename obj))
      (list en1 pt T)
    (append en (list nil))
