I have been able to create a dll with the help from people on this forum. Thanks!
Now, I need to be able to use that utility or macro. The way the users want to use it is when they open the drawing they want to simply click a button that will execute the code. How do I set this up to work like that?
Currently, I can execute NETLOAD, select the dll, then type in the command that I want to execute. This is all done manually via the command line. This works very well but not what the user wants. They want this automated. They want to use a macro button.
Thanks.
