Author Topic: AMEP Interference  (Read 5813 times)
MexicanCustard
AMEP Interference
« on: May 27, 2011, 07:25:51 PM »
In AMEP Im trying to tell when a Pipe object passes through a Wall object or a Slab object(so I can sleeve it). Whats the most efficient method since Im doing this inside of a ObjectAppended or an ObjectModified event?
MexicanCustard
Re: AMEP Interference
« Reply #1 on: May 31, 2011, 03:55:59 PM »
I'm bumping my post since "Interference Detection" seems to be taboo in .NET.  Everyone who's figured it out must be keeping the info to themselves to make a profit.  There may be something in LISP but I can't read that gibberish.
Even after a thorough search on the interwebs I can't find anything.  There is some information about IntersectsWith() but within those articles/post someone always comments that these are 2D only.  AMEP has a neat little interference detection dialog, isn't there API to go along with it?
So if I have a vertical Pipe going through a horizontal Slab, will the IntersectsWith() work if they are both drawn in the same plane(doesn't work in MgdDbg or its C++ counterpart)?  Someone out there has to be able to point me in the right direction.
bieres
« Reply #2 on: June 01, 2011, 12:40:11 PM »
Hi MexicanCustard,
If you could try Solid3d Interference.
Using the method of Solid3d CheckInterference.
With that you would know if there is interference and you might get it.
Hola, si son Solid3d podrias intentar con Interferencia.
Usando el metodo CheckInterference de los Solid3d.
Con eso sabrias si hay interferencia y podrias obtenerla.
MexicanCustard
« Reply #3 on: June 01, 2011, 04:21:02 PM »
Thank you for replying, I was starting to wonder if there was a solution.
I'll try your suggestion and post what I find. I'm also going to try the BREP route and see if Slabs and Pipes can be used in BREP routines.
MexicanCustard
« Reply #4 on: June 01, 2011, 08:45:10 PM »
Ok, these three didn't work. So its back to the drawing board.
Point3dCollection pc = new Point3dCollection();
slab.IntersectWith(pipe, Intersect.ExtendBoth, pc, (System.IntPtr)1, (System.IntPtr) 1);
pc.Count is always 0
and:
Brep brp = new Brep(slab); <--- gives me a Boundary Exception
Hit[] hit = brp.GetLineContainment(new Line3d(pipe.StartPoint, pipe.EndPoint), 10);
and:
Solid3d s3slab = new Solid3d();
Solid3d s3pipe = new Solid3d();
s3slab.CreateFrom(slab); <-- eInvalidInput Exception
s3pipe.CreateFrom(pipe);
bool chk = s3slab.CheckInterference(s3pipe);
« Last Edit: June 01, 2011, 08:57:13 PM by MexicanCustard »
bieres
« Reply #5 on: June 02, 2011, 08:48:58 AM »
Hi.
Upload a dwg with your objects to check.
Sube un dwg con tus objectos a comprobar.
MexicanCustard
« Reply #6 on: June 02, 2011, 05:02:08 PM »
This is the drawing I've been using for my test.
Jeff H
« Reply #7 on: June 03, 2011, 04:04:04 AM »
I hate this API it is the worst documented....................I will stop complaining
I think I am getting some where,
To get started off simple,
to test delete all objects in drawings except for the one slab and one pipe that goes through slab.(Make sure only 1 pipe object and 1 slab object in drawing and they intersect)
        [CommandMethod("SlabbyCrappyInterference")]
        public void SlabbyCrappyInterference()
            //SlabInterferenceOption
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction trx = db.TransactionManager.StartTransaction())
                BlockTable blocktable = trx.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;//Assign BlockTable
                BlockTableRecord currentSpace = trx.GetObject(db.CurrentSpaceId, OpenMode.ForRead) as BlockTableRecord;
                Slab slb;
                ObjectId pipeId = ObjectId.Null;
                ObjectId slabId = ObjectId.Null;
                foreach (ObjectId objId in currentSpace)
                    if (objId.ObjectClass.Name == "AecbDbPipe")
                        pipeId = objId;
                    if (objId.ObjectClass.Name == "AecDbSlab")
                        slabId = objId;
                slb = trx.GetObject(slabId, OpenMode.ForWrite) as Slab;
                SlabInterference si = new SlabInterference();
                si.EntityId = pipeId;
                ObjectIdCollection objIdColl = new ObjectIdCollection();
                si.SetEntityBlockRefPath(pipeId, objIdColl, null);
                si.Option = SlabInterferenceOption.Add;
                slb.Interferences.Add(si);
                trx.Commit();
Jeff H
« Reply #8 on: June 03, 2011, 05:04:38 AM »
Now for the wall and same thing one wall and one pipe
Next will try all pipes, walls, slabs however many.
        [CommandMethod("WallCheck")]
        public void WallCheck()
                Wall wall;
                ObjectId wallId = ObjectId.Null;
                        pipeId = objId;
                    if (objId.ObjectClass.Name == "AecDbWall")
                        wallId = objId;
                wall = trx.GetObject(wallId, OpenMode.ForWrite) as Wall;
                WallInterference wi = new WallInterference();
                wi.EntityId = pipeId;
                wi.SetEntityBlockRefPath(pipeId, objIdColl, null);
                wi.ShrinkWrapEffect = WallShrinkWrapEffect.Additive;
                wall.WallInterferences.Add(wi);
                trx.Commit();
Jeff H
« Reply #9 on: June 03, 2011, 07:48:03 AM »
        [CommandMethod("WallSlabby")]
        public void WallSlabby()
                ObjectIdCollection pipeIds = new ObjectIdCollection();
                ObjectIdCollection slabnWallIds = new ObjectIdCollection();
                        pipeIds.Add(objId);
                        continue;
                    if (objId.ObjectClass.Name == "AecDbWall" || objId.ObjectClass.Name == "AecDbSlab")
                        slabnWallIds.Add(objId);
                foreach (ObjectId slabnWallId in slabnWallIds)
                    if (slabnWallId.ObjectClass.Name == "AecDbSlab")
                        Slab slb = trx.GetObject(slabnWallId, OpenMode.ForWrite) as Slab;
                        SlabInterferenceCollection sic = slb.Interferences;
                        foreach (ObjectId pipeId in pipeIds)
                            sic.Add(si);
                    else
                        Wall wall = trx.GetObject(slabnWallId, OpenMode.ForWrite) as Wall;
                        WallInterferenceCollection wic = wall.WallInterferences;
                            wic.Add(wi);
                trx.Commit();
Jeff H
« Reply #10 on: June 06, 2011, 07:31:28 PM »
Is it not working?
MexicanCustard
« Reply #11 on: June 07, 2011, 01:51:14 PM »
Sorry Jeff, I haven't had time to try out your code. I've been side tracked exporting properties out to a SQLite DB for our fabrication shop. Finished the test app today and should be able to get back to this problem this week. I'll definitely try out your code and post back my results. Thanks for helping me out.
MexicanCustard
« Reply #12 on: June 07, 2011, 08:03:05 PM »
                        pipeIds.Add(objId);
                        continue;
                            sic.Add(si);
                    else
                            wic.Add(wi);
                trx.Commit();
Ok, this puts a hole in the slab, the size of the pipe, wherever the pipe goes thru. And it follows the pipe as if it were anchored. It's really neat, but how do I tell if there is an interference within code (without looking at the drawing and seeing the hole).
