Author Topic: List unmarked commands only  (Read 2065 times)
kaefer
« on: January 10, 2011, 11:41:16 AM »
Starting point was Kean's post from almost 4 years ago, http://through-the-interface.typepad.com/through_the_interface/2007/03/getting_the_lis.html#comments.
I tried to modify it in a way that lists the loaded assemblies in which CommandMethodAttributes are defined, but do not have CommandClassAttributes. For our internal development I have yet to see the need to adorn an assembly with a CommandClassAttribute. Why would I want to do this?
F# source follows...
module ListLoadedCommands
open Autodesk.AutoCAD.EditorInput
open Autodesk.AutoCAD.Runtime
type acApp = Autodesk.AutoCAD.ApplicationServices.Application
let CCAtype = typeof<CommandClassAttribute>
let CMAtype = typeof<CommandMethodAttribute>
let toCCA (o: obj) = o :?> CommandClassAttribute
let toCMA (o: obj) = o :?> CommandMethodAttribute
let typeToCommandMethods (tp: System.Type) =
    tp.GetMethods()
    |> Array.collect (fun mi -> mi.GetCustomAttributes(CMAtype, true))
let typeArrayToCommandMethodNames =
    Array.collect typeToCommandMethods
    >> Array.map (fun o -> (toCMA o).GlobalName)
[<CommandMethod "LLC">]
let listLoadedCommandsCmd() =
    let ed = acApp.DocumentManager.MdiActiveDocument.Editor
    let asms = System.AppDomain.CurrentDomain.GetAssemblies()
    for asm in asms do
        let cmdsMarked =
            asm.GetCustomAttributes(CCAtype, true)
            |> Array.map (fun o -> (toCCA o).Type)
            |> typeArrayToCommandMethodNames
        let cmdsUnmarked =
            asm.GetExportedTypes()
            |> Array.filter
                (fun cmd ->
                    match Array.tryFind ((=) cmd) cmdsMarked with
                    | Some _ -> false
                    | None -> true )
        if not(Array.isEmpty cmdsUnmarked) then
            ed.WriteMessage(
                "\n{0}\n{1}\n{2}\n ",
                asm.ManifestModule.Name,
                asm.FullName,
                System.String.Join(", ", cmdsUnmarked) )
Cheers,  Thorsten
dan.glassman
Re: List unmarked commands only
« Reply #1 on: January 10, 2011, 12:36:49 PM »
It's a load-time performance optimization.
If you don't include it, all classes are scanned for [CommandMethod]s.  If you do, only the listed ones are scanned.
Marginal utility for small modules.
-drg
« Reply #2 on: January 10, 2011, 12:46:30 PM »
< .. > Cheers,  Thorsten
wow, time sure flies :)
I'd forgotten about that.
