Author Topic: How to cast an object into another...  (Read 2411 times)
EDDemtec
« on: November 11, 2011, 11:33:46 AM »
Hi Guys !
I would like to learn how to cast an object into another object of a different type, if it's possible...
In my case, I want to cast an ObjectId in a AecWall and get length of the current wall...
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AEC.Interop.ArchBase
Public Class Class1
    <CommandMethod("Class1")> _
    Public Sub Class1()
        '' Get the current document and database, and start a transaction
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            '' Open the Block table record for read
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
            '' Open the Block table record Model space for read
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForRead)
            Dim myWall As New AecWall
            '' Step through each object in Model space and
            '' display the type of object found
            For Each acObjId As ObjectId In acBlkTblRec
                If acObjId.ObjectClass().DxfName = "AEC_WALL" Then
                    'Get wall length here
                End If
            Next
            '' Dispose of the transaction
        End Using
    End Sub
End Class
Thanks in advance !
huiz
  • Certified Prof C3D
Re: How to cast an object into another...
« Reply #1 on: November 11, 2011, 01:52:20 PM »
DirectCast for example.
huiz
« Reply #2 on: November 11, 2011, 01:54:53 PM »
Dim ent As Entity = DirectCast(tr.GetObject(myObjectID, OpenMode.ForRead), Entity)
Otherwise you can have a look at TryCast.
huiz
« Reply #3 on: November 11, 2011, 01:56:35 PM »
Btw, if you only look for one type of object, you can create a Selection with a certain object type as filter. It reduces the loop.
EDDemtec
« Reply #4 on: November 11, 2011, 02:25:01 PM »
Thank you for all !
I found the code below, but I dont want to prompt for a selection, is it possible ?
Imports Autodesk.AutoCAD.EditorInput
Public Class Class2
    <CommandMethod("FilterSelectionSet")> _
    Public Sub FilterSelectionSet()
      '' Get the current document editor
      Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
      '' Create a TypedValue array to define the filter criteria
      Dim acTypValAr(0) As TypedValue
      acTypValAr.SetValue(New TypedValue(DxfCode.Start, "AEC_WALL"), 0)
      '' Assign the filter criteria to a SelectionFilter object
      Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
      '' Request for objects to be selected in the drawing area
      Dim acSSPrompt As PromptSelectionResult
      acSSPrompt = acDocEd.GetSelection(acSelFtr)
      '' If the prompt status is OK, objects were selected
      If acSSPrompt.Status = PromptStatus.OK Then
          Dim acSSet As SelectionSet = acSSPrompt.Value
          Application.ShowAlertDialog("Number of objects selected: " & acSSet.Count.ToString())
      Else
          Application.ShowAlertDialog("Number of objects selected: 0")
      End If
    End Sub
End Class
« Last Edit: November 11, 2011, 02:45:09 PM by EDDemtec »
« Reply #5 on: November 11, 2011, 04:33:45 PM »
Look at using the acDocEd.SelectAll(acSelFtr) method instead of the GetSelection() method.
EDDemtec
« Reply #6 on: November 14, 2011, 10:32:13 AM »
Thank you very much for your help !
As sample, the code below, select all walls in the drawing...
Public Class FilterSelectionAll
    'Define the command
    <CommandMethod("fsa")> _
    Public Sub fsa()
        acSSPrompt = acDocEd.SelectAll(acSelFtr)
        Else
        End If
    End Sub
End Class
