Author Topic: Delete a layer within a block  (Read 4415 times)
GDF
« on: August 31, 2015, 08:21:03 AM »
Is it possible to delete a layer within a block without using the block editor?
ChrisCarlson
Re: Delete a layer within a block
« Reply #1 on: August 31, 2015, 08:22:59 AM »
As in delete a layer from the drawing or delete an object on that layer?
« Reply #2 on: August 31, 2015, 08:25:36 AM »
Put simply:
  1.     (if (and (= "YourLayerHere" (vla-get-layer obj)) (vlax-write-enabled-p obj))
  2.         (vla-delete obj)
  3.     )
  4. )
GDF
« Reply #3 on: August 31, 2015, 08:31:49 AM »
Thanks Lee.
Perfect!
« Reply #4 on: August 31, 2015, 08:55:46 AM »
You're welcome!  :-)
GDF
« Reply #5 on: August 31, 2015, 12:11:52 PM »
Example of how I'm using your routine:
(defun C:DLB (/ YourBlockHere YourLayerHere)
  (Setq YourBlockHere (cdr (assoc 2 (entget (car (entsel "Select Block: "))))))
  (vlax-for obj (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) YourBlockHere)
    (if (and (= "A-DIMS" (vla-get-layer obj)) (vlax-write-enabled-p obj))
        (vla-delete obj)
« Reply #6 on: August 31, 2015, 12:21:40 PM »
Nice one Gary  :-)
Here are some tweaks to include a little more error trapping to account for null user input, dynamic blocks etc.:
  1. (defun c:dlb ( / ent )
  2.     (while
  3.         (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect block: ")))
  4.             (cond
  5.                 (   (= 7 (getvar 'errno))
  6.                     (princ "\nMissed, try again.")
  7.                 )
  8.                 (   (null ent) nil)
  9.                 (   (/= "INSERT" (cdr (assoc 0 (entget ent))))
  10.                     (princ "\nSelected object is not a block.")
  11.                 )
  12.                 (   t
  13.                     (vlax-for obj
  14.                         (vla-item
  15.                             (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
  16.                             (vla-get-effectivename (vlax-ename->vla-object ent))
  17.                         )
  18.                         (if (and (= "A-DIMS" (vla-get-layer obj)) (vlax-write-enabled-p obj))
  19.                             (vla-delete obj)
  20.                         )
  21.                     )
  22.                     nil
  23.                 )
  24.             )
  25.         )
  26.     )
  27.     (princ)
  28. )
Krushert
  • FREE BEER Tomorrow!!
« Reply #7 on: August 31, 2015, 12:42:55 PM »
  2.     (while
  4.             (cond
  6.                     (princ "\nMISSED IT by that much Agent 99, try again.")
  7.                 )
  11.                 )
  12.                 (   t
  13.                     (vlax-for obj
  14.                         (vla-item
  17.                         )
  20.                         )
  21.                     )
  22.                     nil
  23.                 )
  24.             )
  25.         )
  26.     )
  27.     (princ)
  28. )
My tweak within Lee's Code.    :tongue2:
« Reply #8 on: August 31, 2015, 01:06:15 PM »
 :lol:
ChrisCarlson
« Reply #9 on: August 31, 2015, 01:16:23 PM »
Since we are offering tweaks, utilize Lee's selectif function and make a call to it. Very useful that way.
« Reply #10 on: August 31, 2015, 01:59:08 PM »
Since we are offering tweaks, utilize use Lee's selectif function and make a call to it. Very useful that way.
Here's my 'tweak'  :)
GDF
« Reply #11 on: August 31, 2015, 03:15:55 PM »
Thanks 99
GDF
« Reply #12 on: August 31, 2015, 04:58:15 PM »
another variation:
(defun c:DLBX ( / chgblk obj e i s YourLayerHere YourBlockHere)
  (setq YourLayerHere (strcase (getstring "\n* Enter Layer Name:")))
  (if (= YourLayerHere "")(setq YourLayerHere (strcase "A-DIMS")))
  (defun chgblk (YourBlockHere YourLayerHere)
      (if (and (= YourLayerHere (vla-get-layer obj)) (vlax-write-enabled-p obj))
        (vla-delete obj)
  (if (setq s (ssget "X" '((2 . "`unit*"))))
        (setq i (1- (sslength s)))
          (while (<= 0 i)
                (setq e (ssname s i)
                      YourBlockHere (cdr (assoc 2 (entget e)))
                      i (1- i)
                (chgblk (strcase YourBlockHere) YourLayerHere)
« Reply #13 on: August 31, 2015, 06:22:55 PM »
Careful Gary - consider that we are modifying the block definition for these blocks, and so this change need only be performed once for each block name.
If you are looking to modify all blocks with name starting "unit", it becomes far more efficient to iterate directly over the block collection, i.e.:
  1. (defun c:dlbx nil
  2.         (if (wcmatch (strcase (vla-get-name blk) t) "unit*")
  3.             (vlax-for obj blk
  4.                 (if (and (= "A-DIMS" (strcase (vla-get-layer obj))) (vlax-write-enabled-p obj))
  5.                     (vla-delete obj)
  6.                 )
  7.             )
  8.         )
  9.     )
  10.     (princ)
  11. )
GDF
« Reply #14 on: August 31, 2015, 07:06:16 PM »
Thanks Lee
