Author Topic: migrating VBA Import  (Read 10600 times)
dbroada
Re: migrating VBA Import
« Reply #15 on: September 22, 2010, 09:34:25 AM »
right, clearly out of my depth here (but thanks for the help so far). At least I know what I want can be done, its just that I can do it.  :-(
here is the code I am (attempting to) running. If I uncomment the Dim acDoc As AcadDocument = doc.AcadDocument line I get an error message (hopefully produced below).
To my understanding VB 2010 express doesn't support debugging but by use of MsgBox I know that is the line it is failing on. Before I give up for winter  :cry: is there anything obvious that I haven't yet done?
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports System.IO
Imports AcadApp = Autodesk.AutoCAD.ApplicationServices.Application
Public Class Hellooo
    <CommandMethod("Ducks", CommandFlags.Modal + CommandFlags.Session)> _
    Public Sub DucksIn()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim pr As PromptResult = ed.GetString(vbCrLf & "Enter File: ")
        If pr.Status = PromptStatus.OK Then
            Dim myFile As String = pr.StringResult
            Dim fNameNoExt = Path.GetFileNameWithoutExtension(myFile)
            'Dim acDoc As AcadDocument = doc.AcadDocument
            Dim p1 As Point3d = Point3d.Origin
            Dim myScale As Double = 1
            If File.Exists(myFile) Then
                myFile = fNameNoExt
            ElseIf Not File.Exists(fNameNoExt & ".dxf") Then
                MsgBox("File does not exist")
            End If
            myScale = 1
            'acDoc.Import(myFile, p1, myScale)
        End If
    End Sub
« Reply #16 on: September 22, 2010, 09:55:28 AM »
How about this
' CodeHimBelonga kdub@theSwamp 20100922
Imports System
Imports System.IO
Imports System.Windows.Forms
Namespace ducks_vb_
    Public Class MyCommands
        <CommandMethod("Ducks", (CommandFlags.Modal + CommandFlags.Session))> _
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim pr As PromptResult = ed.GetString(("" & vbCrLf + "Enter qualified File: "))
            If Not (pr.Status = PromptStatus.OK) Then
                Return
            End If
            If Not File.Exists(myFile) Then
                Dim msg As String = String.Format("File {0} does not exist", myFile)
                MessageBox.Show(msg, "Ooooooops")
                Return
            End If
            Dim comDoc As AcadDocument = CType(doc.AcadDocument, Autodesk.AutoCAD.Interop.AcadDocument)
            Dim ptArray() As Double = p1.ToArray
            comDoc.Import(myFile, CType(ptArray, Object), myScale)
        End Sub
    End Class
End Namespace
I'll be back shortly .. need to go scrub my hands  :lol:
« Last Edit: September 22, 2010, 10:09:10 AM by Kerry »
dbroada
« Reply #17 on: September 22, 2010, 10:01:33 AM »
I thank you now for getting your hands dirty and hopefully I will be back tomorrow (really MUST do some project work today) thanking you for an excellent routine.
« Reply #18 on: September 22, 2010, 10:13:19 AM »
Washed my mouth out too ... vb does that to me  :|
You're welcome ... I learnt stuff too.
Note that I had the CommandFlags OR'd ; I've changed them to And'd
ie
& in C#   [added] WRONG .. should be | or + ; kdub 20100923
+ in VB    <- [added] Can someone confirm this Please ?
« Last Edit: September 22, 2010, 06:31:14 PM by Kerry »
mohnston
  • CAD Programmer
« Reply #19 on: September 22, 2010, 12:44:11 PM »
ie
& in C#
There is both an & operator and an && operator.
I copied the help file below.
The & operator can function as either a unary or a binary operator.
Remarks
The unary & operator returns the address of its operand (requires unsafe context).
Binary & operators are predefined for the integral types and bool. For integral types, & computes the logical bitwise AND of its operands. For bool operands, & computes the logical AND of its operands; that is, the result is true if and only if both its operands are true.
The & operator evaluates both operators regardless of the first one's value.
The conditional-AND operator ( &&) performs a logical-AND of its bool operands, but only evaluates its second operand if necessary.
oh . . . . you meant the vb didn't you? he he
CAD Programming Solutions
« Reply #20 on: September 22, 2010, 06:29:43 PM »
OK, I've checked by testing.
The AutoCAD .NET Developer's Guide Command Definitions page is wrong.  :-o
The example shows the CommandFlags using & in the sample
It SHOULD use | or +
The Values are :
    [Flags]
    public enum CommandFlags
        TempShowDynDimension = -2147483648,
        Modal = 0,
        Transparent = 1,
        UsePickSet = 2,
        Redraw = 4,
        NoPerspective = 8,
        NoMultiple = 16,
        NoTileMode = 32,
        NoPaperSpace = 64,
        NoOem = 256,
        Undefined = 512,
        InProgress = 1024,
        Defun = 2048,
        NoNewStack = 65536,
        NoInternalLock = 131072,
        DocReadLock = 524288,
        DocExclusiveLock = 1048576,
        Session = 2097152,
        Interruptible = 4194304,
        NoHistory = 8388608,
        NoUndoMarker = 16777216,
        NoBlockEditor = 33554432,
        NoActionRecording = 67108864,
        ActionMacro = 134217728,
        NoInferConstraint = 1073741824,
This Piccy Tells the story I think.
I'll advise Kean and see if we can get it fixed.
jgr
« Reply #21 on: September 22, 2010, 07:42:56 PM »
With vb you can use the logical operator. This is correct :
<CommandMethod("Ducks", (CommandFlags.Modal Or CommandFlags.Session))> _
dbroada
« Reply #22 on: September 23, 2010, 05:17:48 AM »
now you are in areas that I have no understanding of I'll just report that I finally have something working. I have got myself so confused with all the error messages I have received! However, now that I have built to Net3.5 (rather than 4) and made the Interop.dll copy local I am seeing results with a very minimal version of Kerry's solution. I will now try with his full solution!!!
Many thanks for your time.
I will be back so lets hope somebody asks a question I can answer before I have built up too much debt.
dbroada
« Reply #23 on: September 23, 2010, 05:30:23 AM »
I didn't think I would be back so soon. Kerry, thank you, your code (almost) works perfectly. The only bit not quite right is around the "oooops" message box but that is not a show stopper. And may well be irrelevant after the next question....
What changes would need to be made to run that routine with a supplied file name? I build up loop diagrams from 3 DXF files and combine them into 1 file. I currently use a script to do this which looks something like
sdi
1
new
acadiso
vbastmt
DxfImport("P:\Design_Office\E281\LOOPS\Output\July-2010\E281-10-LD001-528_0.dxf")
vbastmt
DxfImport("P:\Design_Office\E281\LOOPS\Output\July-2010\E281-10-LD001-528_1.dxf")
vbastmt
DxfImport("P:\Design_Office\E281\LOOPS\Output\July-2010\E281-10-LD001-528_2.dxf")
saveas
2007
"P:\Design_Office\E281\LOOPS\Output\July-2010\E281-10-LD001-528"
resume
ultimately I want to replace the DxfImport bit with the new .Net routine.
Glenn R
« Reply #24 on: September 23, 2010, 09:14:02 AM »
Why you would ever want to combine these 2 flags is beyond me:
Jeff H
« Reply #25 on: September 23, 2010, 02:34:50 PM »
Sorry for the CommandFlags.Modal + CommandFlags.Session
I should of not put it in there thanks for catching that
For the "short circuiting" I thought
C# &&
VB ANDALSO
C# ||
VB ORALSO
