Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Clipit Autolisp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Clipit Autolisp (Read 3667 times)
diago
Guest
Clipit Autolisp
on:
January 06, 2015, 07:48:44 PM »
Hi everyone I work with Autocad 2013 for Mac and this version doesn`t have the "Expresss" tool option, that`s why I can`t use the "Cliptit " command to work with external References. So is there any Autolisp file which could replace this important command?
Thanks in advance!
Last Edit: January 08, 2015, 12:24:35 PM by diago
Logged
diago
Guest
Re: Clipit Autolisp
Reply #1 on:
January 08, 2015, 12:25:21 PM »
I found this auto lisp but doesn't work for me it appears this message :
Command: CLIPIT
; error: no function definition: ACET-ERROR-INIT
Logged
danallen
Guest
Re: Clipit Autolisp
Reply #2 on:
January 08, 2015, 01:25:35 PM »
You need the full express tools support routines with that error handler, and more subfunctions used in the clipit.lsp
Check your installer for AutoCAD, in the past it was a separate option for express tools from the main install menu.
Logged
diago
Guest
Re: Clipit Autolisp
Reply #3 on:
January 08, 2015, 04:26:33 PM »
Unfortunately with Autocad 2013 for Mac "Express Tool" is not an option for using. That`s why I try to use "Clipit" as Autolisp file to work with XReferences.
Logged
danallen
Guest
Re: Clipit Autolisp
Reply #4 on:
January 08, 2015, 04:34:51 PM »
what function are you needing from Clipit? Is it the changing of curves to segments?
Logged
diago
Guest
Re: Clipit Autolisp
Reply #5 on:
January 08, 2015, 06:08:30 PM »
Dan, the definition of "Clipit" command is to provide the option for clipping Xrefs or Images with curves or lines. After that you see that it removes the display of the all other objects.
http://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-1200C4A7-53EC-43C3-8667-749E83FCDD35-htm.html
Last Edit: January 08, 2015, 06:17:39 PM by diago
Logged
diago
Guest
Re: Clipit Autolisp
Reply #6 on:
January 11, 2015, 05:56:41 PM »
Any suggestion?
Logged
Seagull
London, England
WWW
Re: Clipit Autolisp
Reply #7 on:
January 11, 2015, 06:37:42 PM »
Use a PC
Logged
Lee Mac Programming
Twitter
Exchange App Store
danallen
Guest
Re: Clipit Autolisp
Reply #8 on:
January 11, 2015, 08:37:44 PM »
Use Lee's routine to create segmented pline from your curves, then standard xclip command
http://www.lee-mac.com/segmentcurve.html
Logged
Needs a day job
Re: Clipit Autolisp
Reply #9 on:
January 11, 2015, 09:37:12 PM »
Quote from: Lee Mac on January 11, 2015, 06:37:42 PM
Use a PC
X2
Logged
diago
Guest
Re: Clipit Autolisp
Reply #10 on:
January 16, 2015, 05:33:59 PM »
k thanks .
Logged
cmwade77
Swamp Rat
Re: Clipit Autolisp
Reply #11 on:
January 21, 2015, 11:38:54 AM »
Unfortunately, Lee's routine uses VLA commands which don't work in AutoCAD for Mac, so that may not be a choice either.
Logged
rkmcswain
Swamp Rat
WWW
Re: Clipit Autolisp
Reply #12 on:
January 21, 2015, 02:22:51 PM »
Convert your curves to line segments.
Draw your clipping boundary with line segments only.
Use the POLYGON command to create a "circle" or "arc" made from many line segments.
Logged
R.K. McSwain
twitter
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Clipit Autolisp
