Author Topic: Dynamic Block Vis State  (Read 4263 times)
Guest
« on: December 04, 2006, 10:22:57 AM »
Is it possible to change the visibility state of a dynamic block using VBA??  I can't seem to find any properties for visibility states.
Thanks.
Dave R
Re: Dynamic Block Vis State
« Reply #1 on: December 04, 2006, 12:35:24 PM »
Matt -
You can use something along these lines:
Sub SetDynBlockToElevation()
  Dim ent As AcadEntity
  Dim oSSet As AcadSelectionSet
  Dim oBlkRef As IAcadBlockReference2
  Dim vDynProps As Variant
  Dim oDynProp As AcadDynamicBlockReferenceProperty
  Dim iCnt As Long
  Set oSSet = vbdPowerSet("DynBlock")
  oSSet.Select acSelectionSetLast
  Set oBlkRef = oSSet.Item(0)
  vDynProps = oBlkRef.GetDynamicBlockProperties
  For iCnt = LBound(vDynProps) To UBound(vDynProps)
    Set oDynProp = vDynProps(iCnt)
    If oDynProp.PropertyName = "Visibility" Then
      If oDynProp.Value = "Plan" Then
         oDynProp.Value = "Elevation"
      End If
    End If
  Next iCnt
End Sub
Public Function vbdPowerSet(strName As String) As AcadSelectionSet
  Dim objSelSet As AcadSelectionSet
  Dim objSelCol As AcadSelectionSets
  Set objSelCol = ThisDrawing.SelectionSets
    For Each objSelSet In objSelCol
      If objSelSet.Name = strName Then
        objSelCol.Item(strName).Delete
        Exit For
      End If
    Next
  Set objSelSet = objSelCol.Add(strName)
  Set vbdPowerSet = objSelSet
End Function
Guest
« Reply #2 on: December 04, 2006, 01:32:13 PM »
Thanks, but.....
It throws a wobbly right here: Dim oBlkRef As IAcadBlockReference2
Did you have to add any references to anything??  I'm using 2007 (for what it's worth).
Bryco
« Reply #3 on: December 04, 2006, 05:21:44 PM »
As far as I can tell you Dim oBlkRef As IAcadBlockReference2 to get intellisense but after that you can change it to Dim oBlkRef As AcadBlockReference
« Reply #4 on: December 04, 2006, 06:27:20 PM »
This worked for me in 2007, but, as Bryco points out, there is no Intellisense using this method.
Sub test()
Dim oEnt As AcadEntity
Dim vPick As Variant
Dim i As Long
ThisDrawing.Utility.GetEntity oEnt, vPick, "select block: "
If TypeOf oEnt Is AcadBlockReference Then
    Set oBlkRef = oEnt
    If oBlkRef.IsDynamicBlock = True Then
        For i = 0 To UBound(vDynProps)
            Set oDynProp = vDynProps(i)
                Debug.Print oDynProp.Value
            End If
        Next
    End If
End If
End Sub
Dave R
« Reply #5 on: December 05, 2006, 07:54:04 AM »
Matt -
I'm using 2006. 2007 may be a little different.
Thanks, but.....
Dave R
« Reply #6 on: December 05, 2006, 07:55:30 AM »
Bryco -
In AutoCAD 2006 you have to use IAcadBlockReference2 in order to access the GetDynamicBlockProperties method. This may have changed for 2007.
Guest
« Reply #7 on: December 05, 2006, 08:53:07 AM »
Thanks for the help/info everyone!
Bryco
« Reply #8 on: December 05, 2006, 10:10:45 AM »
It works on 2006 for me, did you try it Dave?
Dave R
« Reply #9 on: December 05, 2006, 01:16:22 PM »
Not yet, but I will.
Matt -
Did you manage to make it work for you?
Guest
« Reply #10 on: December 05, 2006, 01:29:03 PM »
Matt -
So far, so good.  I'm going to take some of Jeff's code, some of your code, mix it together, throw it against the wall and see if it sticks (I think it will).  :)
Thanks again!
