I am using acad 2009 and vlisp to copy files from network to local folders. It works great except the copied files have todays date and time. The end result will be used to update semi-dynamic files based on the network versions so comparing file dates and times is a requirement. Is there a way to copy the file and maintain its original attributes?
TIA
