Hi, I use this code to insert my blocks in the drawings. This code insert the block from specific file in to autocad by picking the insert point.
I want to add option
a) pick a point for insert the block
b) To give the point number and insert the block and this can be for multiple points
for example
insert point ? [poiny / number]
> number
20
enter
44
enter
46
enter
enter (<--- for exit)
This is the code I use
(command "_layer" "_m" "DEH" "_c" "33" "" "") *error* at_err)
(setq scl
(getint "\n Set Scale (50,100,200,250,500,etc) :")) (setq scl1
(* scl
0.0025)) (command "insert" "c:\\MBL\\DEH1.dwg" dt1 scl1 scl1
0) )
I attach deh1.dwg is the block for this example and the test.dwg have the points I use (is attribute blocks)
Can any one help?
