Code Red > XDRX-API
[XDrX-PlugIn(149)] Quickly regenerates only objects visible on screen, layers
(1/1)
xdcad:
Quickly regenerates only objects visible on screen, those selected, or a chosen layer.
Support SSGET usage for keywords
--- Code: ---(defun c:xdtb_qregen (/ lyr scrbox ss)
  (xdrx-begin)
  (xdrx_initssget
    (xdrx-string-multilanguage
      "\n选取要Regen的实体[屏幕所有(0)/选图层(1)]<退出>:"
      "\nSelect the entities to be Regen [all on screen (0)/select layer (1)]<Exit>:"
    "0 1"
  (if (and (xdrx-initget "0 1")
   (setq ss (xdrx-ssget))
      (setq typ ss)
((= ss "0")
(setq scrbox (xdrx-get-screenbox)
       scrbox (xdrx-points-dcs2ucs scrbox)
       ss     (ssget "cp" scrbox)
((= ss "1")
(if (setq lyr (xd::layer:get nil t))
   (setq ss (ssget "x" (list (cons 8 lyr))))
      (if (= (type ss) 'pickset)
  (xdrx-object-regen ss)
  (xdrx-prompt
      ((= typ "0")
       (xdrx-string-multilanguage "\n屏幕内," "\nIn screen,")
      ((= typ "1")
       (xdrx-string-multilanguage "\n选择的图层," "\nSelected layer,")
      (t
       "\n"
    (xdrx-string-formatex
"重新生成了%d个实体."
"%d entities were regenerated."
      (sslength ss)
  (xdrx-end)
--- End code ---
Navigation
[0] Message Index
Go to full version
