Code Red > XDRX-API
[navigation] XDRX API sub-forum navigation post (2024.05.01)
V@no:
And just while we are on the subject. If this modifies any system registry, environmental PATH, or copies any files beyond its folder, please provide detailed uninstall instructions.
It's Alive!:
--- Quote from: V@no on April 27, 2024, 09:26:32 AM ---And just while we are on the subject. If this modifies any system registry, environmental PATH, or copies any files beyond its folder, please provide detailed uninstall instructions.
--- End quote ---
FYI, my recommendation “path to %PATH% with SetEnvironmentVariable” doesn’t stick
It’s just for the process
https://learn.microsoft.com/en-us/windows/win32/api/winbase/nf-winbase-setenvironmentvariable
--- Quote ---SetEnvironmentVariable
Sets the contents of the specified environment variable for the current process
This function has no effect on the system environment variables or the environment variables of other processes.
--- End quote ---
xdcad:
--- End quote ---
The special situation you encountered,
Under normal circumstances, there is no need to copy any files to other places.
Only path and trustedpath paths are set
V@no:
Ok, so I got it working by adding path to XDRX-API/SYS folder to "Support File Search Path" in AutoCAD options.
Navigation
[0] Message Index
[*] Previous page
Go to full version
