Author Topic: AecDwgSetup scale  (Read 5082 times)
Matt__W
  • I like my water diluted.
AecDwgSetup scale
« on: August 10, 2011, 04:36:08 PM »
Trying to get back to my LSP roots.
I'd like to change the scale in the AECDWGSETUP dialog box, but I don't know what the sysvar is?  Anyone??!?
(Arch/MEP 2011)
Autodesk Expert Elite
Matt__W
Re: AecDwgSetup scale
« Reply #1 on: August 10, 2011, 04:45:47 PM »
I think I can get away with using -AECDWGSETUP and go through the command line options.
But just for future reference, what IS the sysvar for the aec scales?
BlackBox
« Reply #2 on: August 10, 2011, 06:29:56 PM »
Matt,
I'm not that familiar with MEP, so I'm unsure of what SysVar(s) may be available to you there, but I can tell you that Land Desktop used a block named ADCADD_ZZ which held this sort of 'project' data.
Perhaps the 2011 version will offer you more feature functionality... Try digging through SYSVDLG command.
BlackBox
« Reply #3 on: August 10, 2011, 06:31:40 PM »
Found this in a quick search.
alanjt
  • Standby for witty remark...
« Reply #4 on: August 10, 2011, 06:34:06 PM »
The AECC settings won't be in the sysvdlg.
Dropbox
BlackBox
« Reply #5 on: August 10, 2011, 06:37:11 PM »
Thanks for clarifying; I wasn't sure.
alanjt
« Reply #6 on: August 10, 2011, 08:13:58 PM »
No problem. I like the new snazzy avatar.
Dropbox
Matt__W
« Reply #7 on: August 11, 2011, 08:15:43 AM »
I'm sure JB would know but I haven't seen him around here in a while.
irneb
« Reply #8 on: August 11, 2011, 09:33:07 AM »
I'm not sure about MEP, but in ACA this info is saved into a dictionary: AEC_VARS under the namedobjdict. This is in turn also a dictionary with an item called AEC_VARS_DWG_SETUP ... but doing an entget or even a vlax-dump-object on it gives absolutely no info whatsoever.
I think it's the same problem as RenderMan's mentioned in other posts: No way to get at these Verticals' data without DotNet/ARX. Painful aint it?
Matt__W
« Reply #9 on: August 11, 2011, 09:49:56 AM »
Nothing is jumping out at me at the moment.  :\
This is what dbview shows.
irneb
« Reply #10 on: August 11, 2011, 10:02:46 AM »
Did basically the same thing through my old DictEdit lisp:
« Reply #11 on: August 11, 2011, 11:02:53 AM »
Command: cannoscale
Enter new value for CANNOSCALE, or . for none <"1/8" = 1'-0"">: 1/4\" = 1'-0\"
Command: cannoscale
Enter new value for CANNOSCALE, or . for none <"1/4" = 1'-0"">: 1/8" = 1'-0"
(getvar 'CANNOSCALEVALUE)
(/ 1 (getvar 'CANNOSCALEVALUE))
BlackBox
« Reply #12 on: August 11, 2011, 12:00:05 PM »
Thanks!  :-D
Jeff H
« Reply #13 on: August 11, 2011, 12:11:43 PM »
Are talking about the default value for new drawings?
Change it in the dialog box and click the
Save as default
I think you set one up for metric and imperial
