Author Topic: Better database viewer?  (Read 9058 times)
LE
Re: Better database viewer?
« Reply #15 on: February 13, 2006, 06:36:39 PM »
For all the ones interested.... here is ARXDBG.arx it is part of a sample project solution that comes with the ARX SDK... it will run on AutoCAD 2004-2006 and vertical products.
It does not have any notice of not distribution, so hope it is OK....
Read the .DOC file
MickD
« Reply #16 on: February 13, 2006, 06:52:33 PM »
That does look excellent Michael, nice job!
The database structure is the area struggle most with although I'm getting there. I started with vba and only hacked some code to make my work easier with what little I knew about the db.
This is an area where coming from lisp would be a huge advantage but I have enough on my plate without going there ;). I'll have to have a closer look at these app's in future!
- John Carmack
- J.R.R. Tolkien
zoltan
« Reply #17 on: February 15, 2006, 10:00:10 AM »
Thanks Luis, I will look into this one.
Joe Burke
« Reply #18 on: February 16, 2006, 08:56:30 AM »
Thanks, Luis. Looks interesting.
Daniel Eiszele
« Reply #19 on: November 18, 2015, 05:05:42 AM »
Can anyone recommend an database explorer like those in this thread that would work with Bricscad? I was sure I'd seen something before but all the googling I've done returns zilch.
