Author Topic: Check is AttributeReference instance of concrete AttributeDefinition?  (Read 2571 times)
Andrey Bushman
Hello all.
I have next instances:
1. BlockTableRecord
2. BlockReference
3. AttributeDefinition
4. AttributeReference
How can I check is AttributeReference instance of concrete AttributeDefinition?
I look next properties of AttributeReference object: ObjectId, OwnerId, BlockId, but it's not help me (it's ID's for other objects)...
kpblc
Maybe TagString?
Sorry for my English.
Andrey Bushman
Maybe TagString?
No it's bad answer. Such property is absent. There is property "Tag". But AttributeDefinition in other BlockTableRecord can have same "Tag" value.
kpblc
Da you really think it's right? If you'll try to change attribute values (with same tags), you'll get window with red strings (unique tags have black color).
I think this situation have to be changed.
P.S. But! Can you get all attributes by order of them?
Andrey Bushman
look screen:
I select 2 instances of different blocks. Look attrib. name in property window: names same.
I don't need change - I need filter.
Yes I can.
Andrey Bushman
question closed (I was inattentive).
result:
