Author Topic: Compare 2 strings & return a list of strings with the differences?  (Read 8459 times)
Re: Compare 2 strings & return a list of strings with the differences?
« Reply #30 on: December 22, 2006, 03:25:47 PM »
So am I out of luck now?
I thought we where making some good progress before this posting one different (unrelated) sites issue came up...
Think the issue now is the Holidays, not the cross posting issue.  You may have to wait until next year, unless there are some people like me who have to work for the next couple of weeks, and have time/desire to do what you are asking.
« Reply #31 on: December 22, 2006, 03:57:42 PM »
Here.  This is as close as I can get what I think would be useful.
(defun CompareStrings (String1 String2 / cnt1 cnt2 Str tempStr StrList)
(setq cnt1 1)
(setq cnt2 1)
(setq Str "")
(while (and (<= cnt1 (strlen String1)) (<= cnt2 (strlen String2)))
 (setq tempStr (substr String2 cnt2 1))
 (if (= (substr String1 cnt1 1) tempStr)
  (setq Str (strcat Str tempStr))
   (if (/= Str "")
    (setq StrList (cons Str StrList))
   (setq Str tempStr)
   (setq cnt2 (1+ cnt2))
   (while (and (/= (substr String1 cnt1 1) (setq tempStr (substr String2 cnt2 1))) (<= cnt2 (strlen String2)))
   (setq StrList (cons (list Str) StrList))
   (setq Str "")
 (setq cnt1 (1+ cnt1))
(if (and (/= Str "") (/= Str (car StrList)))
(if (<= cnt1 (strlen String1))
 (reverse (cons (substr String1 cnt1) StrList))
 (reverse StrList)
Returned this for your two test strings in the first post.
Command: (comparestrings a b)
("This is" ("n't") "a test")
("1" ("x3") "3")
  • Custom Title
« Reply #32 on: December 22, 2006, 04:31:24 PM »
What have you coded thus far? Maybe we can get back into it, it is an interesting problem.
I've got an idea! How about looking at the source code for GNU diff. Yea it's in C but you might be able to glean some info on how they do it and translate that into autolisp.
« Reply #34 on: December 26, 2006, 04:24:13 AM »
good find Daniel ...
that boy < Joshua Tauberer > sure has a heavy reading list  :?
