Author Topic: Missing in a sequence  (Read 1688 times)
velasquez
« on: July 04, 2014, 08:16:54 AM »
Can anyone tell me how to find the first value that is missing in a sequence from the list below?
'("1" "2" "3" "?" "7" "8")
Thanks,
velasquez
ElpanovEvgeniy
  • Moscow (Russia)
Re: Missing in a sequence
« Reply #1 on: July 04, 2014, 08:32:45 AM »
  1. (setq l'("1" "2" "3" "?" "7" "8"))
  2. (car(acad_strlsort l))
velasquez
« Reply #2 on: July 04, 2014, 09:21:41 AM »
Sorry ElpanovEvgeniy,
I used the symbol "?" wrongly.
What I need to figure out is the amount to complete the sequence.
For example "4"
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #3 on: July 04, 2014, 11:26:50 AM »
First I did not understand the task...
  1. (defun test (l / f)
  2.   ;; (test '("1" "2" "3" "?" "7" "8"))
  3.   (defun f (a b)
  4.     ;; test sequence function for '("1" "2" "3" "?" "7" "8")
  5.     (if (/= (1+ (atoi a)) (atoi b))
  6.       (itoa (1+ (atoi a)))
  7.     )
  8.   )
  9.   (cond ((not (cdr l)) nil)
  10.         ((f (car l) (cadr l)))
  11.         ((test (cdr l)))
  12.   )
  13. )
dgorsman
« Reply #4 on: July 04, 2014, 02:24:27 PM »
First you need to identify if the sequence is regular or irregular.  The former can be distilled into a function for generating successive numbers.  The latter cannot so will require some sort of lookup table.  In your given example, the sequence is irregular since you only specify one missing entry.  For it to be regular there would have to be multiple missing entries and an identified function.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
« Reply #5 on: July 05, 2014, 09:45:32 AM »
Another couple:
  1. (defun f ( l )
  2.     (vl-some '(lambda ( a b ) (if (/= (1+ (atoi a)) (atoi b)) (itoa (1+ (atoi a))))) l (cdr l))
  3. )
  1. (defun f ( l )
  2.     (setq l (mapcar 'atoi l))
  3.     (vl-some '(lambda ( a b ) (if (/= a b) (itoa a))) (mapcar '1+ l) (cdr l))
  4. )
  1. _$ (f '("1" "2" "3" "?" "7" "8"))
  2. "4"
And another way to write Evgeniy's:
  1. (defun f ( l )
  2.     (if (cadr l)
  3.         (if (= (1+ (atoi (car l))) (atoi (cadr l)))
  4.             (f (cdr l))
  5.             (itoa (1+ (atoi (car l))))
  6.         )
  7.     )
  8. )
Or a generalised function:
  1. (defun missing ( l f )
  2.     (vl-some '(lambda ( a b / c ) (if (/= b (setq c (f a))) c)) l (cdr l))
  3. )
  4. (missing '("1" "2" "3" "?" "7" "8") (lambda ( x ) (itoa (1+ (atoi x)))))
« Last Edit: July 05, 2014, 10:01:14 AM by Lee Mac »
velasquez
« Reply #6 on: July 07, 2014, 01:39:31 PM »
Many thanks for all the answers.
