Author Topic: Detect AutoCAD version  (Read 9429 times)
Daniel J. Ellis
Re: Detect AutoCAD version
« Reply #15 on: January 11, 2011, 04:24:52 PM »
Thanks CAB, et al, it's the ACAD version I need, so RTOS (ACADVER) is the way to go.
I'll probably read the wikilink just to be geeky, though ^_^
Ronjonp, If I read your method right it searches for the acad.exe file and extrapolates the version from the path?  Could this differential between two different versions on the same computer (I have both R2011 and R2010 installed)?
dJE
http://en.wikipedia.org/wiki/.dwg
No info on 2011 yet.
There are many ways to do it.
Drawing version
http://www.theswamp.org/index.php?topic=6774.msg333989#msg333989
ACAD version
((= (rtos(atof(getvar "ACADVER"))2 2) "15.00") 2000))
 ((= (rtos(atof(getvar "ACADVER"))2 2) "15.05") 2000i))
 ((= (rtos(atof(getvar "ACADVER"))2 2) "15.06") 2002))
 ((= (rtos(atof(getvar "ACADVER"))2 2) "16.00") 2004))
 ((= (rtos(atof(getvar "ACADVER"))2 2) "16.10") 2005))
 ((= (rtos(atof(getvar "ACADVER"))2 2) "16.20") 2006))
 ((= (rtos(atof(getvar "ACADVER"))2 2) "17.00") 2007)) ; 7 8 9
 ((= (rtos(atof(getvar "ACADVER"))2 2) "18.00") 2010))
dJE
« Reply #16 on: January 11, 2011, 04:26:27 PM »
my version
(atoi (substr (ver) 13))
Bravo  8-)
alanjt
  • Standby for witty remark...
« Reply #17 on: January 11, 2011, 04:27:15 PM »
dJE
Drawing version
ACAD version
Beware of your dimzin variable being something other than zero (suppressing zeros will cause problems when comparing strings).
Dropbox
« Reply #18 on: January 11, 2011, 04:37:28 PM »
personally I prefer this:
(atoi (vl-string-right-trim " (en)" (vl-string-left-trim "Visual LISP " (ver))))
(defun getacadversion (/)
  (vl-list->string
    (vl-remove-if-not (function (lambda (x) (and (> x 47) (< x 58)))) (vl-string->list (ver)))
I like that one  8-)  Forgot about (ver)  :lol:
« Reply #19 on: January 11, 2011, 04:38:33 PM »
alanjt
« Reply #20 on: January 11, 2011, 04:39:26 PM »
my version
Bravo  8-)
X2
X3
He has a way of making us all look/feel stupid and happy, at the same time.
Dropbox
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #21 on: January 11, 2011, 04:47:37 PM »
Mood has improved! Thank you :)
« Reply #22 on: January 11, 2011, 05:26:24 PM »
Whichever AutoCAD version the code is run in should match... unless for some reason the other acad path is in the search paths as well.
did.ave
« Reply #23 on: January 12, 2011, 04:53:41 AM »
coucou
Evgeniy is always the most concise
i'm french, so I say merci
amicalement
Chris
« Reply #24 on: January 12, 2011, 08:46:27 AM »
my version
Bravo  8-)
X2
X3
X4 - I'm changing my code.
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
MeasureUp
« Reply #25 on: January 12, 2011, 06:19:44 PM »
