You generally don't load CABs or Se7ens code into AutoCAD - it'll create havoc
Ok, ok, I'll be nice. Copy the code to a text editor or VisualLISP, save as file with extension ".lsp", return to AutoCAD and type (load "whateverfilename") at the command line.
Or, in VisualLISP, choose Tools->Load Text in Editor after having copied it to a document in VLIDE.
Then run by typing (Del_Plot_config_list)
