Code Red => .NET => Topic started by: bikelink on February 12, 2009, 06:50:55 AM
this code run correctly...only if the viewport is more bigger in Y than 20 or somthing simlar... ! :-o :-o
Why ? the objectid is ok, the handle is ok.,..just Number stay -1! but only if the viewport is little in Y side..
You guess an A3 format...
in x 413 in y 20 ...NUmber > 0
in x 413 in y 10.8 ...NUmber -1
Thanks in advance...i need help this time...any suggestion will be appreciated.!
public static ObjectId MakeViewport(Document d, Point2d s)
ObjectId viewportID = ObjectId.Null;
Database db = d.Database;
if (B2UtilCad.B2Editor.b2Editor.IsPaperSpace(db) == false)
System.Windows.Forms.MessageBox.Show("you're not in Paper Space");
return viewportID;
using (DocumentLock l = d.LockDocument())
using (Transaction t = d.Database.TransactionManager.StartTransaction())
Point3d pt1 = new Point3d(0, 0, 0);
Point3d pt2 = new Point3d(s.X, s.Y, 0);
Viewport vport = new Viewport();
vport.Height = (double)Math.Abs(pt1.Y - pt2.Y);
vport.Width = (double)Math.Abs(pt1.X - pt2.X);
// da controllare la sottrazione dei due vettori
//Vector3d ptc = pt2.GetAsVector().Subtract(pt1.GetAsVector());
vport.CenterPoint = new Point3d(pt2.X / 2, pt2.Y / 2, 0);
vport.SetDatabaseDefaults();
BlockTable bt = (BlockTable)t.GetObject(db.BlockTableId, OpenMode.ForWrite, false);
BlockTableRecord blkRec = (BlockTableRecord)t.GetObject(bt[BlockTableRecord.PaperSpace], OpenMode.ForWrite, false);
blkRec.AppendEntity(vport);
vport.On = true; // can't be set until after it is added to database
vport.SnapOn = false;
vport.Color = Autodesk.AutoCAD.Colors.Color.FromColor(System.Drawing.Color.Red);
int vpNum = vport.Number;
t.AddNewlyCreatedDBObject(vport, true);
vport.UpdateDisplay();
t.Commit();
viewportID = vport.ObjectId;
return viewportID;
added code tags
the zoom in paper space is the problem. :pissed: :pissed: :pissed: :pissed: :pissed: :pissed:
bleah!
so, the answer to the problem is ??
... or was your problem what you thought it was ??
If I look from distant the layout in paperspace and I build a little viewport, (don't ask me why and the scale..) autocad return -1 in number property.
If I perform a zoom similar to size of viewport that i'm going to build...also with a very very little size autocad return > 1 ;)
This is a big bug...IMHO.
The behavior of this property is very very strange, 'cause you see the viewport..in your drawing. in the first case in code you'havent the right setting...in number property .
at the stop of your code...if you ask autocad the entget (via lisp example..) of this viewport you see a right setting! but when you run the code the build this little viewport, if you don't have a zoom in paper space...it pass from 0 to -1 until your code is terminated
and the docs in arx/managed about viewport is pure fantasy...it's talks about property that doesn't exist. Bad, very very bad..autodesk.
Believe if I said that i'm going crazy to resolve this... :ugly: :ugly:
from help-Gets the viewport ID number. This is the number that is reported by the AutoCAD CVPORT system variable when the viewport is the current viewport in the AutoCAD editor. If the viewport is inactive, -1 is returned.
The number is describing the state of the vp
I knew of course.. but isn't the trouble. You can make active the viewport via number...but the number exists property of your viewport.
example : if you have 3 viewports in your layout and you check via entget the number you see 2,3,4 as field...but just on is current (of course)
I'm sure of this... and if you try to run the code and build different viewport with very small size you can verify this...
if you build a little viewport in a layouy saw from distant the viewport is -1.
the same code with the same layout zoomed ...return > 1
