Author Topic: How to get Selection set from model space into newly created paperspace  (Read 2187 times)
Proctor
Hello: I'm trying to figure out how to get a selection set from model space into my newly created paperspace:
When my application runs, the user often will open an existing drawing. Often time, there could be several drawings in model space and the user is generating a new drawing to go into this same model space. After, they need to get the new drawing into a custom template (new paperspace).
I created a BOM command that currently loads the custom template into a new paperspace. I still need to include code that will  ask the user to select the objects from model space that they want to go into the new paperspace. This part I can do...
Here's the part I need help with...How do I get the objects the user selects into the new paperspace???
I think perhaps I will need to do a zoom extents; after that, I will need to write code that works like the MView... is this correct? am I on the right track?
here's my current BOM command (if it will help):
<CommandMethod("BOM")> (modified code originally derrived from Fatty)_
    Sub BOM()
        Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor()
        Dim num As Double = iModulesPerUnit 'this number represents the distance between the leds given the product chosen
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim idLayout As ObjectId = ObjectId.Null
        'PARSE OUT WINDOWS AUTHENTICATION AUTHORIZATION TO GET THE FIRST,LAST INITIAL OF THE USER'S LOGIN
        Dim sUserLoginInit As String
        sUserLoginInit = UCase(wiUserLogin.Substring(0, 2))
        Dim iIncrementText As Integer = 0
        Dim myBT As DatabaseServices.BlockTable
        Dim myBTR As DatabaseServices.BlockTableRecord
        Dim myBTE As DatabaseServices.SymbolTableEnumerator
        Dim myLayout As New DatabaseServices.Layout
        Dim sLayoutName As String = ""
        Dim sLayoutNameParsedRight As String
        Dim sLayoutNameParsedRightRev As String
        Using docLock As DocumentLock = ed.Document.LockDocument()
            Using trans As Transaction = ed.Document.TransactionManager.StartTransaction()
                Dim filename As String = "C:\Documents and Settings\rproctor\Local Settings\Application Data\Autodesk\AutoCAD 2008\R17.1\enu\Template\SLOAN_TEMPLATE_rev.dwt"
                Dim layoutname As String = "Layout"
                Dim sNewLayoutName As String = "SLOAN_LED"
                Dim dbSource As New Database(False, False)
                Try
                    dbSource.ReadDwgFile(filename, System.IO.FileShare.Read, True, Nothing)
                    Dim idDbdSource As ObjectId = dbSource.LayoutDictionaryId
                    Dim dbdLayout As DBDictionary = DirectCast(trans.GetObject(idDbdSource, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead, False, False), DBDictionary)
                    For Each deLayout As DictionaryEntry In dbdLayout
                        Dim sLayout As String = deLayout.Key.ToString()
                        If sLayout.ToUpper() = layoutname.ToUpper() Then
                            idLayout = DirectCast(deLayout.Value, ObjectId)
                            Exit For
                        End If
                    Next
                    If idLayout <> ObjectId.Null Then
                        Dim idc As New ObjectIdCollection()
                        idc.Add(idLayout)
                        Dim im As IdMapping = New IdMapping()
                        Dim dbdict As DBDictionary = DirectCast(trans.GetObject(db.LayoutDictionaryId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, False, False), DBDictionary)
                        dbdict.UpgradeOpen()
                        db.WblockCloneObjects(idc, db.LayoutDictionaryId, im, DuplicateRecordCloning.MangleName, False)
                        Dim ip As IdPair = im.Lookup(idLayout)
                        idLayout = ip.Value
                        Dim lm As LayoutManager = LayoutManager.Current
                        lm.CurrentLayout = layoutname
                        dbdict.DecomposeForSave(DwgVersion.Current)
                        'LOOK TO SEE IF LAYOUT NAMED SLOAN_ESTIMATE ALREADY EXISTS
                        'if yes, look to see if sloan_estimate1 exists
                        'keep going till get unique layout name
                        myBT = db.BlockTableId.GetObject(DatabaseServices.OpenMode.ForRead)
                        myBTE = myBT.GetEnumerator
                        'ASSIGN UNIQUE LAYOUT NAME
                        While myBTE.MoveNext
                            myBTR = myBTE.Current.GetObject(DatabaseServices.OpenMode.ForRead)
                            If myBTR.IsLayout Then
                                myLayout = myBTR.LayoutId.GetObject(DatabaseServices.OpenMode.ForRead)
                                ' MsgBox(myBTR.Name & vbCr & myLayout.LayoutName)
                                If InStr(myLayout.LayoutName, "SLOAN_ESTIMATE") = 1 Then
                                    'if there's already a layout that has at least part of this name
                                    ' If InStr(1, myLayout.LayoutName, "SLOAN_ESTIMATE") = 1 Then
                                    'see if there's anything concatenated with "SLOAN_ESTIMATE" LENGTH OF "SLOAN_ESTIMATE"=14
                                    If myLayout.LayoutName.Length >= 14 Then
                                        If sLayoutName = "" Then
                                            sLayoutNameParsedRight = myLayout.LayoutName.Substring(14, myLayout.LayoutName.Length - 14)
                                            If sLayoutNameParsedRight = "" Then
                                                sLayoutNameParsedRight = "0"
                                            End If
                                            sLayoutName = "SLOAN_ESTIMATE" & (sLayoutNameParsedRight + 1)
                                        Else
                                            'Do a check of the new assignment
                                            'if we had already assigned a new layout name, need to make sure there's not another like it
                                            'check the number for the layout
                                            End If
                                            'here's the number it assigned to the last time. is it the same?
                                            sLayoutNameParsedRightRev = sLayoutName.Substring(14, sLayoutName.Length - 14)
                                            If sLayoutNameParsedRight = sLayoutNameParsedRightRev Then 'if it equals it, need to assign a new name
                                            End If
                                        End If
                                    End If
                                End If
                            End If
                        End While
                        End If
                        LayoutManager.Current.RenameLayout("Layout", sLayoutName)
                        ed.Regen()
                    End If
                    Dim layoutObj As Layout = DirectCast(trans.GetObject(idLayout, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead), Layout)
                    Dim layoutBtr As BlockTableRecord = trans.GetObject(layoutObj.BlockTableRecordId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, True)
                    Dim entId As ObjectId
                    Dim iIncrement As Integer = 0
                    For Each entId In layoutBtr
                        Dim ent As Entity = trans.GetObject(entId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, True)
                        'Debug.Print("ent type: " & vbTab & ent.GetType.ToString)
                        If TypeOf ent Is MText Then
                            Dim txt As MText
                            txt = CType(ent, MText)
                            ' Debug.Print("text" & vbTab & txt.Contents.ToString)
                            If InStr(txt.Contents.ToString, "X", CompareMethod.Text) Then
                                Select Case iIncrement
                                    Case 0
                                        'FIRST TEXT BLOCK
                                        'FILLS IN PRODUCT, COLOR, IOC, CAN DEPTH
                                        '1st line:
                                        txt.Contents = Replace(txt.Contents.ToString, "X", sModuleType.ToString, , 1)
                                        txt.Contents = Replace(txt.Contents.ToString, "X", sLEDColor.ToString, , 1)
                                        txt.Contents = Replace(txt.Contents.ToString, "X", iModulesPerUnit.ToString, , 1)
                                        txt.Contents = Replace(txt.Contents.ToString, "X", inchesOnCenter.ToString, , 1)
                                        txt.Contents = Replace(txt.Contents.ToString, "X", sVinylUsed.ToString, , 1)
                                        '2nd line
                                        '3rd line
                                        txt.Contents = Replace(txt.Contents.ToString, "X", UCase(sCanDepth).ToString, , 1)
                                        iIncrement = iIncrement + 1
                                    Case 1
                                        ''2ND TEXT BLOCK
                                        ''FILLS IN PRODUCT, COLOR, IOC, CAN DEPTH
                                        txt.Contents = Replace(txt.Contents.ToString, "X", dCountTotal.ToString, , 1)
                                End Select
                            End If
                        End If
                        If TypeOf ent Is DBText Then
                            Dim txt As DBText
                            txt = CType(ent, DBText)
                            If InStr(txt.TextString.ToString, "X", CompareMethod.Text) Then
                                Debug.Print("DBText" & vbTab & txt.TextString.ToString)
                                If iIncrementText = 0 Then
                                    txt.TextString = Replace(txt.TextString.ToString, "X", sUserLoginInit.ToString, , 1)
                                End If
                                If iIncrementText = 1 Then
                                    txt.TextString = Replace(txt.TextString.ToString, "X", Format(Now, "short date"), , 1)
                                End If
                                If iIncrementText = 2 Then
                                    txt.TextString = Replace(txt.TextString.ToString, "X", sCustomer.ToString, , 1)
                                End If
                                If iIncrementText = 3 Then
                                    txt.TextString = Replace(txt.TextString.ToString, "X", sCompanySignName.ToString, , 1)
                                End If
                                iIncrementText = iIncrementText + 1
                            End If
                        End If
                    Next
                    trans.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    MsgBox(ex.StackTrace)
                    'MessageBox.Show(ex.ToString(), "Error", MessageBoxButtons.OK, MessageBoxIcon.[Error])
                Finally
                    trans.Dispose()
                    dbSource.Dispose()
                End Try
            End Using
        End Using
Attatched is a pic how my BOM command currently runs. You can see that the pic isn't anywhere near the center of the viewport. The second pic shows how I need it to look.
Any thoughts, dirrection is truly appreciated.
proctor
