Author Topic: Acad 2008 dbview.arx  (Read 6444 times)
TR
« on: October 31, 2007, 11:18:45 AM »
I have done some searching and I have yet to come up with a solution. For the life of me I can't find dbview.arx for AutoCAD 2008. I am writing a program that reads and writes custom dictionaries to the drawing database. I am looking for some kind of solution to just view them like in dbview. Anyone know of anything comparable
LE
Re: Acad 2008 dbview.arx
« Reply #1 on: October 31, 2007, 11:33:57 AM »
Tim;
As far as I know/think the 2007 binary might work on the 2008 - give it a try
http://autodesk.blogs.com/between_the_lines/2006/07/dbview_for_auto.html
TR
« Reply #2 on: October 31, 2007, 01:16:18 PM »
Tim;
Worked like a charm. Thanks for the info. Didn't think a 2007 binary would work with 2008 but once again I'm wrong.
Jan ter Aij
« Reply #3 on: November 08, 2007, 11:35:29 AM »
Dear Readers,
Sorry, it is not good to rename dbview.arx .
Is there also an AutoCAD 2007 version of Arxdbg.arx
Regars Jan
« Last Edit: November 12, 2007, 03:22:19 AM by Jan ter Aij »
« Reply #4 on: November 12, 2007, 03:36:49 AM »
Arxdbg.arx can be built from the code in the SDK
..\ObjectARX 2008\samples\database\ARXDBG
Jan ter Aij
« Reply #5 on: November 12, 2007, 04:17:34 AM »
Dear Kerry,
To build it, is there a C++ compiler needed?
Regards Jan.
« Reply #6 on: November 12, 2007, 04:22:33 AM »
yes,
Try this ..
Jan ter Aij
« Reply #7 on: November 12, 2007, 04:36:43 AM »
yes,
Try this ..
Thanks Kerry.
Regards Jan.
« Reply #8 on: November 12, 2007, 08:56:31 AM »
hmmmm ... Vista Ultimate / AutoCAD 2008 ...
Command: (ARXLOAD "C:/Docs/Arx/ArxDbg.arx")
C:\Docs\Arx\ArxDbg.arx is an invalid ARX file.
« Reply #9 on: November 12, 2007, 09:02:05 AM »
That was built with VS2005
and loads on XPpro into AC2007 and AC2008 here Michael.
« Reply #10 on: November 12, 2007, 09:08:02 AM »
Interesting; thanks Kerry.
« Reply #11 on: November 12, 2007, 09:16:51 AM »
wild thought ... 64 bit ?
« Reply #12 on: November 12, 2007, 09:17:36 AM »
Nada: 32 bit each, but good thinking.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #13 on: November 12, 2007, 09:24:21 AM »
Kerry, if you have VS 2005 SP1, you may need to disable the manifest, or others may have troubles
« Reply #14 on: November 12, 2007, 09:39:57 AM »
The build date is telling :)
Created: Sunday, 1 April 2007, 17:58:34
My Cpp compiler has been spitting the dummy for a few days, so I cant rebuild it unfortunately  ;
Error   1   fatal error C1902: Program database manager mismatch;
please check your installation
c:\ObjectARX 2008\samples\database\ARXDBG\StdAfx.cpp
