Hello!
I´m not really a friend with the look of CivilLabel (for example boring rotate them...), so I was thinking how can I convert a CivilEntity in a normal AutocadEntitiy - exactly explode the label, but than I get a anonym block without attributes, so I don´t happy also with them. The other thing is, labelValue is a string not a attribut - stupid???
If I pick on a explode lable (->block ) with this code
(defun c:test ()
(if (setq Vent (vlax-ename->vla-object (car (nentsel "\Select a label "))))
(vlax-dump-object Vent t)
(textpage)
TextString = "{\\Fisocp.shx|c0;79.24}"
So maby there is a way to convert string in a attribut
Any suggestions ?
