Author Topic: In Data link Table losing prperties after breaks table  (Read 1567 times)
HasanCAD
« on: May 20, 2015, 10:04:07 AM »
Hi
After linking an excel file to AutoCAD and break the table into 2 rows then close the file and open all format imported from excel such as text height background color.
Re: In Data link Table losing prperties after breaks table
« Reply #1 on: May 20, 2015, 10:09:03 AM »
have you set up the table style properties correctly?
and or try importing saved cell ranges into two different tables so you do not need to split the table
« Reply #2 on: May 20, 2015, 10:09:53 AM »
As this is a sheet list; why are you not using sheet set manager to generate your sheet list(s)?
HasanCAD
« Reply #3 on: May 20, 2015, 10:36:51 AM »
Thanks all
All projects we submit LOD as an Excel sheets but this project the clint asked for DWG file.
We are not using Sheet set.
ChrisCarlson
« Reply #4 on: May 20, 2015, 11:03:22 AM »
If you are not using the SSM, there isn't really an advantage to using a datalink. By default the datalink is not updated automatically, simply making a table and formatting to your liking and copying into each drawing layout would prove much easier, even easier would be a seperate .dwg and placing an xref of the table into each drawing.
