Lot Numbering
CAB:
dan,
If you are happy with the BLOCK "lotnumber" you could use entmake
to create it and not worry about trying to locate it.
Just another approach. :)
Jeff_M:
--- Quote from: CAB ---dan,
--- End quote ---
Heh, I had actually composed a response to suggest just this.....then I found the problem with the original code and deleted that response.
Most of my own routines utilize this method to reduce the number of dependent files that I have to maintain.
GMTA!
Jeff
Navigation
[0] Message Index
[*] Previous page
Go to full version
