Author Topic: Can file be opened, one method  (Read 19458 times)
LE
Re: Can file be opened, one method
« Reply #30 on: September 06, 2006, 07:25:54 PM »
...make sense?
Yep....
Claro como el lodo Glenn -  :-)
« Reply #31 on: September 06, 2006, 07:28:27 PM »
So then if I set it back after the first foreach statement, then it should be all good?  That is how I have it right now.
Glenn R
« Reply #32 on: September 06, 2006, 07:31:44 PM »
BTW, Tony did make SPECIFIC mention, that if you change the owrking database for whatever reason, make VERY sure you reset when you're done or Acad could become unstable at best, crash at worst.
I suppose you could, but you would want to make damn sure that any possible error is trapped and if fatal enough, reset the working database back in the catch.
LE, the 'using' statement with the 'new database' makes sure the new database is deleted (C++) / disposed (C#) when the using statement's scope ends.
Cheers,
Glenn.
« Last Edit: September 06, 2006, 07:33:06 PM by Glenn R »
« Reply #33 on: September 06, 2006, 07:33:54 PM »
Thanks for keeping an eye on my coding Glenn.  It is very helpful, and I appreciate it.  :-)
« Reply #34 on: September 06, 2006, 07:46:01 PM »
... as do we all. Thanks for the illumination Glenn.
//kwb
LE
« Reply #35 on: September 06, 2006, 07:46:24 PM »
Thank you Glenn.
Claro como el lodo -> clear as mud....
Tim;
For some reason your code posted has a lot of squares characters and it is somehow confused at least for my eyes.... and yes you have the call of "using" statement.... before opening the new database....
Thanks.
Glenn R
« Reply #36 on: September 06, 2006, 08:07:26 PM »
The squares are from me - tab characters/spaces that I was trying to remove/got added, to get the formatting right when I pasted in the code.
Yes, Tim does have the 'using' for the new database, however the issue I was referring to was the WorkingDatabase and the changing and resetting of it.
To all, you're welcome.
Cheers,
Glenn.
« Reply #37 on: September 06, 2006, 09:38:45 PM »
Indeed.
