Author Topic: Polyline join  (Read 5782 times)
ANA
Polyline join
« on: May 15, 2008, 10:23:35 AM »
A polyline-joining routine that works in BricsCad (which doesn't accept an M option for Pedit):
;; Join Into polyline - joins a set of contiguous lines, arcs, and/or polylines into a polyline.
;; Selection window can include inappropriate entities, which are ignored.
(defun c:JI ()
(princ "Join lines, arcs, polylines into a single polyline. ")
(sssetfirst nil nil)
(setq ent1 nil)
(while (= ent1 nil) (setq ent1 (entsel "Pick first entity: ")) )
(setq type1 (cdr (assoc 0 ent1) ))
(setq ss1 (ssget '((-4 . "<OR") (0 . "LINE") (0 . "ARC") (0 . "LWPOLYLINE") (-4 . "OR>"))))
(if (= type1 "LWPOLYLINE") (command "Pedit" ent1 "j" ss1 "" ))
(if (/= type1 "LWPOLYLINE") (command "Pedit" ent1 "y" "j" ss1 "" ""))
(sssetfirst nil (ssget "L"))
« Last Edit: May 15, 2008, 10:50:36 AM by ANA »
Re: Polyline join
« Reply #1 on: May 15, 2008, 10:29:41 AM »
Welcome to The Swamp.  8-)
daron
Re: Polyline join
« Reply #2 on: May 15, 2008, 02:14:10 PM »
Here's one I had lying around for years and decided to upgrade about a month ago. It should also work in BCad.
; PLedit ;
; Main Function ;
; Usage: (plmod (how wid) ("j" nil) or ("w" 4) ;
;Author: unknown ;
;Major upgrade: Daron Rogers 2008 ;
;_______________________________________________________________;
(defun mapvars;|Creates paired lst of progvars|;()
     (mapcar '(lambda (x)
   (cons x (getvar x))
     (list "attdia" "cecolor"     "celtype"
   "celweight"   "cmdecho"     "offsetdist"
   "clayer" "dimsah"      "dimzin"
   "expert" "ltscale"     "osmode"
   "plinewid" "snapmode"    "thickness"
   "users1" "users2"      "users3"
   "errno"
(defun remapvars;|resets lst from mapvars|;(lst)
     (mapcar '(lambda (x) (setvar (car x) (cdr x))) lst)
(defun pledit (how wid / osm cmd sset ename etype *error*)
     (defun *error* (msg)
  (if (not (member msg
   '("console break"
     "Function cancelled"
     "quit / exit abort"
    (princ (strcat "\nError: " msg))
  (remapvars map)
     (command "_.undo" "be")
     (setq map (mapvars)
   ename t
     (remapvars '(("cmdecho" . 0) ("osmode" . 0)));fixed
     (if (or (= how "j") (= how "c"))
  (setq sset (vl-catch-all-apply
  '(lambda ()
(ssget (list
    '(-4 . "<OR") '(0 . "*LINE") '(0 . "ARC")
    '(-4 . "OR>") '(-4 . "<NOT") '(0 . "SPLINE")
    '(-4 . "NOT>") '(-4 . "<NOT") '(-4 . "&")
    '(70 . 1) '(-4 . "NOT>"))
  '(lambda ()
(ssget (list
    '(0 . "*LINE,ARC")
     (if (= sset nil)
  (setq ename nil)
     (while ename
  (cond ((setq ename (ssname sset 0))
(setq etype (cdr (assoc 0 (entget ename))))
(cond ((= how "j")
(cond ((or (= etype "POLYLINE")
   (= etype "LWPOLYLINE")
       (command ".pedit" ename how sset "" "x")
       (setq sset (ssget "p"))
      (t
       (command ".pedit" ename "y" how sset ""
"x")
       ((= how "w")
       (command ".pedit" ename how wid "x")
       (ssdel (ssname sset 0) sset)
      (t
       (command ".pedit" ename "y" how wid "x")
       (t
      (command ".pedit" ename how "")
     (t
      (command ".pedit" ename "y" how "x")
(t
(setq ename nil)
  (if (= sset nil)
       (setq ename nil)
     (remapvars map)
     (command "_.undo" "e")
) ;_ end of defun
(defun c:plj()
     (prompt "\nSelect the objects to Join: ")
     (pledit "j" nil)
(defun c:plc ()
     (prompt "\nSelect the objects to Close: ")
     (pledit "c" nil)
) ;_ end of defun
(defun c:pld ()
     (prompt "\nSelect the objects to Decurve: ")
     (pledit "d" nil)
(defun c:plf ()
     (prompt "\nSelect the objects to Fit Curve: ")
     (pledit "f" nil)
(defun c:plo ()
     (prompt "\nSelect the objects to Open: ")
     (pledit "o" nil)
(defun c:pls ()
     (prompt "\nSelect the objects to Spline Fit: ")
     (pledit "s" nil)
(defun c:plw(/ init width)
     (setq init "0.0"
   width (getreal
      (strcat "\nSpecify width of objects: <"
      init
     (prompt "\nSelect the objects to Widen: ")
     (pledit "w" width)
« Last Edit: May 16, 2008, 06:33:29 AM by Daron »
Re: Polyline join
« Reply #3 on: May 15, 2008, 02:23:16 PM »
alanjt
  • Standby for witty remark...
Re: Polyline join
« Reply #4 on: May 15, 2008, 09:39:30 PM »
man, daron your's is really nice. i think i will dump mine a do a little borrowing :)
mine was just real simple:
;join multiple lines/arcs/polylines
;created: alan thompson
(defun c:mj(/ lines)
(princ "\nSelect lines & arcs to JOIN: ")
(setq lines (ssget '((0 . "*LINE,ARC"))))
(if lines
(equal (getvar 'peditaccept) 1)
(command "pedit" "m" lines "" "j" "" "")
(command "pedit" "m" lines "" "y" "j" "" "")
);if
);progn
(princ (strcat "\nHey " (getvar "loginname") " it helps if you actually selected something to work with!"))
);if
Dropbox
It's Alive!
  • Retired
  • AKA Daniel
Re: Polyline join
« Reply #5 on: May 15, 2008, 09:55:09 PM »
Here is the one I posted at the Bricscad forum, (based off what John@ theBricscadforum posted)
Seems to work   :-o
(DEFUN C:PJ (/ OBJECT OBJECTNAME OBJTYPE OKOBJECTS OLDCMDECHO SS1)
 (SETQ OKOBJECTS '((0 . "LINE,ARC,POLYLINE,LWPOLYLINE")))
 (PRINC "\nSelect object to join: ")
 (SETQ OLDCMDECHO (GETVAR "CMDECHO")
       SS1 (SSGET OKOBJECTS)
 (SETVAR "CMDECHO" 0)
 (IF (/= SS1 NIL)
  (PROGN
   (SETQ OBJECT (ENTGET (SSNAME SS1 0))
OBJECTNAME (CDR (CAR OBJECT))
OBJTYPE (CDR (ASSOC 0 OBJECT))
   (IF (= (SSLENGTH SS1) 1)
    (SETQ SS1 (SSGET "X" OKOBJECTS))
   (IF (MEMBER OBJTYPE '("LINE" "ARC"))
    (COMMAND "_.pedit" OBJECTNAME "Y" "J" SS1 "" "")
    (COMMAND "_.pedit" OBJECTNAME "J" SS1 "" "")
 (SETVAR "CMDECHO" OLDCMDECHO)
 (PRINC)
It's Alive!
  • Retired
  • AKA Daniel
Re: Polyline join
« Reply #6 on: May 15, 2008, 09:58:55 PM »
Oh, and welcome to TheSawmp ANA, 8-)
It's Alive!
  • Retired
  • AKA Daniel
Re: Polyline join
« Reply #7 on: May 15, 2008, 10:43:18 PM »
I think a few small things need to be changed in order for this to run in Bricscad.
(load "dcrutils") MIA
(vl-undobegin) Not Yet Implemented
(varmap '("cmdecho" "osmode") '(0 0)) MIA
(vl-undoend) Not Yet Implemented
And I got an infinite loop if the first item is a polyline
Nice coding though, it would definitely be worth the time make the little changes needed  :kewl:
daron
Re: Polyline join
« Reply #8 on: May 16, 2008, 12:06:45 AM »
Sorry about that Daniel. The (load ...) was meant to be removed. All it does is pull in the variable mapping that I put in with it.
Yes, the vl-undo's could be replaced easily and the (varmap...) I think could be removed and replaced with one of the two variable functions in the beginning. When I realized it was redundant with another I stopped using it and forgot to replace it here. As for the infinite loop if the first item is a polyline, I'll have to look into that as I haven't noticed it. Also, before I read your comments, I noticed that I have a vl-catch-all-apply in there. Is that also going to cause problems for BCad?
It's Alive!
  • Retired
  • AKA Daniel
Re: Polyline join
« Reply #9 on: May 16, 2008, 12:18:20 AM »
....I noticed that I have a vl-catch-all-apply in there. Is that also going to cause problems for BCad?
I think your good using vl-catch-all-apply, it didn’t thrown an exception  :-D
daron
Re: Polyline join
« Reply #10 on: May 16, 2008, 12:27:12 AM »
Daniel, thanks for the comments. I posted that just as I was leaving work and I didn't browse through it to make sure it was cleaned up for public consumption. I will look into that infinite loop problem tomorrow.
I think your good using vl-catch-all-apply, it didn't thrown an exception  :-D
Good deal. Thanks. You using an Asian keyboard. I just noticed your single quote looked like a box with numbers in it?
(if lines
);if
);progn
);if
Alan, I truly appreciate the praise. The original one was real simple, though the concept was intact with all the options individualized. The problem I had with it was that it had code functions in multiple places and I wanted it as an all-in-one function. I know that comes with its own problems as Daniel pointed out. I also wanted a bit more functionality than it originally had, so I added those options, like not selected a closed polyline if my intent is to join or close a polyline and to also not select objects that couldn't be processed. BTW, I love the prompt in yours. That's funny. Now, you need to add the AutocadSpeak program to go with it. I'd love to hear it pronounce my work computers username; "Hey drogers pick something that I can work with you idiot."
Re: Polyline join
« Reply #11 on: May 16, 2008, 01:34:28 AM »
Daron,
Making the *error* routine local may help too ..
(defun pledit (how wid / osm cmd sset ename etype *error* )
daron
Re: Polyline join
« Reply #12 on: May 16, 2008, 06:34:08 AM »
Thanks Kerry. We'll see how that goes.
alanjt
Re: Polyline join
« Reply #13 on: May 16, 2008, 12:10:45 PM »
(if lines
);if
);progn
);if
lol, awesome.
(if lines
);if
);progn
(princ (strcat "\nHey " (getvar "loginname") " it helps if you actually select something to work with!"))
(sayit (strcat "HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA" (getvar "loginname") "sucks"))
);progn
);if
(defun SayIt (Phrase$ / Sapi)
  (setq Sapi (vlax-create-object "Sapi.SpVoice"))
  (vlax-invoke Sapi "Speak" Phrase$ 0)
  (vlax-release-object Sapi)
);defun SayIt
athompson sounds like "ahh thompson"
« Last Edit: May 16, 2008, 12:14:22 PM by alanjt »
Dropbox
daron
Re: Polyline join
« Reply #14 on: May 16, 2008, 03:13:51 PM »
That's good.
