Hi everyone.
I'm trying to figure out how to enable the user to rotate the jig/block during insertion.
I want the user to be able to rotate the jig/block with 90 degrees each time user presses spacebar.
I have made some methods so that i can place a block with a jig, and all that works great.
Only place where i can think of geeting the spacebar input is in the overridden Sampler(JigPrompts prompts) method. If i set UserInputControls.NullResponseAccepted then i can get a PromptStatus.None form the prompt that's being returned when spacebar is pressed. But i don't get a insertion point so it messes things up...
When i do this the jig disappears from the screen and the comman gets messed up.
I'm totally lost, need some help, hints, anything that can get me on track to a solution.
