Author Topic: Removing the saved path of an attached image  (Read 1791 times)
iliekater
« on: June 24, 2007, 08:20:26 AM »
I have inserted (attached) some images in drawing of mine , but I no longer want them to metain their saved path (as seen in the Image Manager) . I want instead only their Name to be saved (since I am going to place then in a support path - I am no longer going to use a full path) . Is it possible ?
Re: Removing the saved path of an attached image
« Reply #1 on: June 24, 2007, 10:45:15 AM »
Yes, use the ImageFile property of the Raster object. Set it to equal the the Name property and this will remove the Path.
(if (ssget "x" '((0 . "IMAGE")))
    (setq ss (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))))
    (vlax-for obj ss
       (vla-put-ImageFile obj (vla-get-name obj))
Not tested but it should be close to what you need.
