Author Topic: Flisp?  (Read 2743 times)
Jeff H
Flisp?
« on: March 04, 2011, 06:43:46 AM »
Was thinking and the best person to probably know how well it would work would be gile.
But I started to mess around and used F# to try to make it  look and feel like AutoLisp.
Defining functions
let setq a b =
    let a = b
    a
let getpoint (prompt:string) =
    let doc = Application.DocumentManager.MdiActiveDocument
    let db = doc.Database
    let ed = doc.Editor
    let pnt = ed.GetPoint(prompt)
    pnt.Value
let car lst =
    match lst with
    |[_] -> Some(lst.Head)
    |hd :: tail -> Some(hd)
    |[] -> None
let cdr lst =
    match lst with
    |hd :: tail -> Some(tail)
    |_ -> None
or more like lisp returning a list
    let ed = doc.Editor
    [pnt.Value.X; pnt.Value.Y; pnt.Value.Z]
but when the functions are used to look like Lisp but all .NET
setq pnt (getpoint "pick point")
I thought I could get more familiar with F# and learn Lisp at the same time.
Was wondering if anyone had ideas or input.
gile
  • Marseille, France
Re: Flisp?
« Reply #1 on: March 04, 2011, 04:43:59 PM »
Maybe a good way for those who knows F# and want to learn LISP, but, excepted 'functional programing style' LISP and F# are so different (mostly dynamic typing vs strong typing).
By my side I try, in the reverse way, to implement some F# List functions which don't exist in AutoLISP here.
gile
  • Marseille, France
Re: Flisp?
« Reply #2 on: March 04, 2011, 07:57:22 PM »
Some more here.
« Last Edit: March 05, 2011, 05:15:46 PM by gile »
hermanm
Re: Flisp?
« Reply #3 on: March 18, 2011, 11:39:28 PM »
car & cdr are built-in:
> let foo = [1;2;3;4];;
val foo : int list = [1; 2; 3; 4]
> List.head foo;;
val it : int = 1
> List.tail foo;;
val it : int list = [2; 3; 4]
(you can also use the older (ML) names, i.e., List.hd and List.tl)
so are cons, append, foreach & mapcar:
> 25::foo;;
val it : int list = [25; 1; 2; 3; 4]
> foo @ [12];;
val it : int list = [1; 2; 3; 4; 12]
> List.append foo [12];;
más por la manaña...
