Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
(command-s ^C)cancle activeCMD
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: (command-s ^C)cancle activeCMD (Read 1478 times)
xinxirong
Mosquito
on:
June 05, 2018, 12:27:01 AM »
in old version CAD,I can use this code to cancle the command
(command "cmdName" arg1 arg2 ... ^C)
but in 2014
(command-s ^C) not success
Logged
Crank
Water Moccasin
Re: (command-s ^C)cancle activeCMD
Reply #1 on:
June 05, 2018, 02:10:47 AM »
I'm surprised that the first option did work.
You can still use COMMAND, how about:
Code:
[Select]
(command-s "cmdName" arg1 arg2 ... (command))/code]
Logged
Vault Professional 2023 + AEC Collection
xinxirong
Mosquito
Reply #2 on:
June 05, 2018, 02:37:16 AM »
but you know why I use command-s?in repeat,mapcar,while etc Loop program,command will cause error.
Logged
roy_043
Water Moccasin
BricsCAD 18
Reply #3 on:
June 05, 2018, 03:09:01 AM »
Isn't ^C actually a variable that evaluates to nil?
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Reply #4 on:
June 05, 2018, 04:30:15 AM »
I suppose you are using A2015 that has that issue VVC error...
From my testings A2014- and A2016+ don't have problems with (command) inside (mapcar '(lambda ( ... )) ...) (while) and (repeat X) loops...
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
xinxirong
Mosquito
Reply #5 on:
June 05, 2018, 05:41:48 AM »
I get it
(command-s ....)
(vla-SendCommand mydoc "\e");cancle activeCMD
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
