Hey guys,
Before I spend the time which would not be too much, I wanted to check if you guys would be interested first.
Was checking if guys would want to advise, contribute, or test with some libraries that would make common task easier and save some lines of code.
I could start off with posting the complete libraries I have built and I do not mind sharing, but I think it would be too much and not implemented the way it should for community use.
I was thinking it would be better to start off with a simple small solution just to act as placeholder for getting everything setup.
The solution is definitely not meant to be a starting point because I think it needs to discussed how to structure the solution, naming conventions, defined rules, etc......
I know this is vague, but I think we can come up with something useful that would help with common task.
If you want a example I will just use the last thing I added which was functionality for basically getting, setting, exporting, importing all the searchpaths on the files tab in options, to treat them like profiles without all the other crap. It uses DLR so other than requiring 4.0 it is not dependent on AcadApplication version, and for settings with multiple paths you treat them as a collection instead of string separated with ";", and had functionality for "temporary or project" paths which would add and remove "extra paths". That seems like something that would be useful but maybe not.
If you guys are interested then I will place project on GitHub and will be private, but will add anyone who wants to join, and of course will out updates here.
So you guys down?
