Author Topic: AutoCAD Extension Framework  (Read 6952 times)
Jeff H
« on: May 17, 2013, 05:10:44 AM »
Hey guys,
Before I spend the time which would not be too much, I wanted to check if you guys would be interested first.
Was checking if guys would want to advise, contribute, or test with some libraries that would make common task easier and save some lines of code.
I could start off with posting the complete libraries I have built and I do not mind sharing, but I think it would be too much and not implemented the way it should for community use.
I was thinking it would be better to start off with a simple small solution just to act as placeholder for getting everything setup.
The solution is definitely not meant to be a starting point because I think it needs to discussed how to structure the solution, naming conventions, defined rules, etc......
I know this is vague, but I think we can come up with something useful that would help with common task.
If you want a example I will just use the last thing I added which was functionality for basically getting, setting, exporting, importing all the searchpaths on the files tab in options, to treat them like profiles without all the other crap. It uses DLR so other than requiring 4.0 it is not dependent on AcadApplication version, and for settings with multiple paths you treat them as a collection instead of string separated with ";", and had functionality for "temporary or project" paths which would add and remove "extra paths". That seems like something that would be useful but maybe not.
If you guys are interested then I will place project on GitHub and will be private, but will add anyone who wants to join, and of course will out updates here.
So you guys down?
« Last Edit: June 25, 2013, 07:46:46 PM by Jeff H »
Keith Brown
Re: AutoCAD Extension Framework
« Reply #1 on: May 17, 2013, 03:00:51 PM »
I could definitely test and possibly contribute.  I am not sure how much a beginner can contribute but I would give it my best shot.  I left the advise portion out for obvious reasons.
WILL HATCH
« Reply #2 on: May 17, 2013, 05:18:05 PM »
I'm down!
mohnston
  • CAD Programmer
« Reply #3 on: May 17, 2013, 06:02:50 PM »
I'll do what I can. I have some block attribute and dynamic block setting code that might be of interest.
This isn't going to be written in F# is it? :wink:
Just kidding. I'll take what I can get.
CAD Programming Solutions
BlackBox
« Reply #4 on: May 18, 2013, 01:45:24 AM »
Jeff,
This is incredibly kind of you to offer/suggest. I'd very much appreciate an opportunity to test what is shared, contribute where I can, and learn a great deal while I'm at it, frankly.
Cheers :beer:
MexicanCustard
« Reply #5 on: May 20, 2013, 08:01:13 AM »
Im in!
Jeff H
« Reply #6 on: May 29, 2013, 08:47:40 PM »
Great!
Been busy as hell, and drunk all memorial day weekend but got GitHub, etc... setup and will get startup post posted soon.
bargool
« Reply #7 on: May 30, 2013, 01:54:22 AM »
I'm in again!
Jeff H
« Reply #8 on: June 14, 2013, 03:15:42 AM »
Finally got a little something together that is to just get discussion started.
Do you think I should load it here or do you guys want to get through GitHub?
WILL HATCH
« Reply #9 on: June 14, 2013, 10:43:47 AM »
Probably get more attention here.
bargool
« Reply #10 on: June 14, 2013, 10:50:01 AM »
I think that GitHub is much-much better for developing with all this commits, pull requests, issue/bug trackers, branches e.t.c., than forum. And this forum is good for discussion, ideas and information about framework.
sybold
« Reply #11 on: June 17, 2013, 03:11:08 PM »
github works great for bug tracking, and tracking changes.
dgorsman
« Reply #12 on: June 18, 2013, 10:24:45 AM »
Providing separate forks for C# and VB?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #13 on: June 18, 2013, 10:33:14 AM »
Forkin' eh.
Jeff H
« Reply #14 on: June 18, 2013, 11:49:33 AM »
Most use C#, but if anyones want to do whole assembly in VB fine by me.
Marking the assemblies  CLSCompliant.
