using Autodesk.AutoCAD.ApplicationServices.Core;
namespace DV2177.Common
/// <summary>
/// Provides easy access to several "active" objects in the AutoCAD
/// runtime environment.
/// </summary>
public static class Active
/// <summary>
/// Returns the active Editor object.
/// </summary>
public static Editor Editor
get { return Document.Editor; }
/// <summary>
/// Returns the active Document object.
/// </summary>
public static Document Document
get { return Application.DocumentManager.MdiActiveDocument; }
/// <summary>
/// Returns the active Database object.
/// </summary>
public static Database Database
get { return Document.Database; }
/// <summary>
/// Sends a string to the command line in the active Editor
/// </summary>
/// <param name="message">The message to send.</param>
public static void WriteMessage(string message)
Editor.WriteMessage(message);
/// <summary>
/// Sends a string to the command line in the active Editor using String.Format.
/// </summary>
/// <param name="message">The message containing format specifications.</param>
/// <param name="parameter">The variables to substitute into the format string.</param>
public static void WriteMessage(string message, params object[] parameter)
Editor.WriteMessage(message, parameter);
