CAD Forums => CAD General => Topic started by: ELOQUINTET on March 11, 2004, 09:38:10 AM
Title: block question
Post by: ELOQUINTET on March 11, 2004, 09:38:10 AM
i'm doing a complicated stair section which i have made a block so i can copy it out and make changes easily. i have added some dimensions and notes to the block. what i'm wondering is this: is there a way to make a block with leaders and dimensions so that if the block is mirrored the text rejustifys itself?
Post by: ELOQUINTET on March 11, 2004, 09:46:59 AM
ummm disregard my last question i realized i'll only be showing the detail once so who cares if it mirrors on the opposite side duh. my next question though is since i have incorported the dimensions and leaders into the block when i redefine it the model takes eternity to regenerate. is there anything i can do to help this?
Post by: ronjonp on March 11, 2004, 10:08:09 AM
Dan,
Was just looking at some tof the variables and don't know if this will help you but....:
Type: Integer
Saved in: Drawing
Initial value: 1
Controls how theMIRROR command reflects text.
0  Retains text direction
1  Mirrors the text
Ron :D
Post by: ronjonp on March 11, 2004, 10:11:06 AM
The variable is MIRRTEXT  :oops:
Post by: ELOQUINTET on March 11, 2004, 10:24:29 AM
yeah i have mine set to 0 but in blocks the text mirrors  :cry:
Post by: ELOQUINTET on March 11, 2004, 10:25:47 AM
i have split the block into a bottom and top section which seems to have helped  :wink:
Post by: hyposmurf on March 11, 2004, 02:20:16 PM
Is the block text actually an attribute? If its not it will just mirror with the rest of the block.
