Author Topic: I would like to create a custom distance  (Read 5685 times)
CECE_CAD
« on: October 25, 2007, 10:01:50 AM »
I would like to create a custom distance command.  Would it be easier to begin with the regular distance command or to use "getdist"..?
Re: I would like to create a custom distance
« Reply #1 on: October 25, 2007, 10:08:17 AM »
It would be easier to begin with getpoint.
CECE_CAD
« Reply #2 on: October 25, 2007, 10:13:42 AM »
ok, I will try that..
I have started reading George O. Head "AutoLISP" in plain english.  So I'm really just learning how to do this.
« Reply #3 on: October 25, 2007, 11:13:09 AM »
Here is what a search pulled up.
Get Distance
Get Length
Look at some of the shorter routines.
BTW, we love questions. :-)
CECE_CAD
« Reply #4 on: October 25, 2007, 11:35:58 AM »
Cab, those are more advanced then me... :laugh:  I will have to use the book I'm reading to follow them.. I will do my best, all I'm really trying to do is make a distance command that allows more then two points..  I saw a lisp with the links you provided me that I'm sure will work I just have to understand how it works..
Get Distance
Get Length
« Last Edit: October 25, 2007, 11:40:20 AM by CECE_CAD »
« Reply #5 on: October 25, 2007, 12:07:57 PM »
Here is a simple distance adding routine using picked points...each line is commented to show what is going on:
(defun c:test (/ pt1 pt2 dist cntr);;localize variables pt1 pt2 dist cntr
  (setq cntr 0);;set distance counter to 0
  (while (if pt2;;if pt2 exists set pt1 = pt2 for start point
   (setq pt1 pt2);;pt2 exists so set pt1 = pt2
   (setq pt1 (getpoint "\nSelect point: "));;pt2 does not exist yet so select point
      (setq pt2 (getpoint pt1 "\nSelect next point: ");;next point to select
    dist (distance pt1 pt2);;get the distance between the points
    cntr (+ dist cntr);;add the distance to the counter
      (grdraw pt1 pt2 1);;visually show line between picked points
      (princ (rtos cntr));;print the results to command line using "rtos" to convert the counter to a string
Hope this helps you understand.
Ron
« Last Edit: October 25, 2007, 12:19:38 PM by ronjonp »
Josh Nieman
« Reply #6 on: October 25, 2007, 12:15:25 PM »
Ron
Excellent post!  Thanks much for the break down.  I'm learnededing.
« Reply #7 on: October 25, 2007, 12:21:27 PM »
Good to hear  :-)
gile
  • Marseille, France
« Reply #8 on: October 25, 2007, 12:31:12 PM »
here's the one I use.
You can specify 2 points or select an object, if the selected object is a polyline boyh total length and selacted segment length are returned.
(defun c:dist (/ p1 p2 ent obj tot par)
  (if (setq p1
     (getpoint
       "\nSpecify the first point or <Select an object>: "
      (while
(not (setq p2 (getpoint p1 "Specify the second point: "))
      (princ (strcat
       "\nDistance : "
       (rtos (distance p1 p2))
    (if (and (setq ent (entsel))
     (not (vl-catch-all-error-p
    (setq p2
   (vl-catch-all-apply
     'vlax-curve-getEndParam
     (list (setq obj (vlax-ename->vla-object (car ent))))
(setq tot (vlax-curve-getDistAtParam obj p2))
(if (wcmatch (cdr (assoc 0 (entget (car ent)))) "*POLYLINE")
    (setq p1  (vlax-curve-getClosestPointToProjection
obj
(trans (cadr ent) 1 0)
(mapcar '-
(trans (getvar "viewdir") 1 0)
(trans '(0 0 0) 1 0)
  par (vlax-curve-getParamAtPoint obj p1)
    (princ
      (strcat
"\nTotal distance: "
(rtos tot)
" Selected segment: "
(rtos
  (- (vlax-curve-getDistAtParam obj (1+ (fix par)))
     (vlax-curve-getDistAtParam obj (fix par))
  (princ (strcat "\nDistance : " (rtos tot)))
      (princ "\nNon valid entity.")
VovKa
  • Ukraine
« Reply #9 on: October 25, 2007, 01:46:12 PM »
my variation of ronjonp's routine
(defun test (/ p1 p2 Dist)
  (setq Dist 0.0)
  (while (and (or (setq p1 p2)
  (setq p1 (getpoint "\nFirst point: "))
  (setq p1 (getvar "LASTPOINT"))
      (setq p2 (getpoint p1 "\nNext point: "))
    (setq Dist (+ Dist (distance p1 p2)))
  (prompt (strcat "\nTotal distance: " (rtos Dist)))
« Reply #10 on: October 25, 2007, 02:57:10 PM »
And my variation.
(defun c:test (/ p1 p2 Dist vecs)
  (setq Dist 0.0)
  (while (and (or p1
          vecs (append vecs (list p1 p2))
          p1 p2)
      (grvecs (append vecs '(1)))
      (print (strcat "  Running total is " (rtos Dist)))
« Reply #11 on: October 25, 2007, 03:02:29 PM »
Nice CAB :) I like the grvecs portion so the line is redrawn if you pan.
VovKa
  • Ukraine
« Reply #12 on: October 25, 2007, 03:51:32 PM »
a "dirty" variation, but with all "pline's" cool stuff :)
(defun c:test (/ Obj)
  (setq Obj (entlast))
  (command "._PLINE")
  (while (/= (getvar "CMDACTIVE") 0) (command PAUSE))
  (if (not (equal Obj (setq Obj (entlast))))
    (progn (prompt
     (rtos (vla-get-Length (setq Obj (vlax-ename->vla-object Obj))))
   (vla-Delete Obj)
   (vlax-release-object Obj)
CECE_CAD
« Reply #13 on: November 12, 2007, 10:19:40 AM »
CAB, This works great.. Could you help me understand it a little more?
(/ p1 p2 Dist vecs)  = your setting p1 p2 as your local variables, is this correct? "dist" is for distance? what is "vecs"
(setq Dist 0.0) = starting with a zero point?
(while (and (or p1 = are you telling the program to look for the first point I pick?
(setq p1 (getpoint "\nFirst point: ")) = then telling it to use p1 as starting messuring point?
(setq p1 (getvar "LASTPOINT")) = Does this set the first point picked to be your starting point?
(setq Dist (+ Dist (distance p1 p2)) = your adding the first two points together
vecs (append vecs (list p1 p2)) = not to sure, but does this allow you to keep picking other points for the distance?
          p1 p2)
     (grvecs (append vecs '(1))) = again not sure..
      (print (strcat "  Running total is " (rtos Dist))) = showing my distance as I'm picking points?  What is "rtos"?
  (prompt (strcat "\nTotal distance: " (rtos Dist))) = then total of all points after I select enter?
Not sure how I did, but can you let me know?
Thanks..
And my variation.
  (setq Dist 0.0)
  (while (and (or p1
          p1 p2)
« Reply #14 on: November 12, 2007, 11:06:22 AM »
You did good.
Here is a commented version & I fixed two mistakes that I did in my haste.
(defun c:test (/ ; Local Variables
               p1    ; First point
               p2    ; Next point:
               Dist  ; Distance acumlated
               vecs  ; vectors to draw
  (setq Dist 0.0)
  (while  ; loop until p2 is nil, i.e. ENTER pressed
    (and  ; make sure p1 & p2 are not nil
      (or p1 ; get p1 only on the first time
    (setq Dist (+ Dist (distance p1 p2))  ; accululate the distance
          vecs (append vecs (list p1 p2)) ; get more vectors
          p1 p2)                          ; shift the point p1 to next point p2
      (grvecs (append '(1) vecs))         ; add color & draw vectors
      (prompt (strcat "  Running total is " (rtos Dist)))
  (princ) ; don't leave anything extra on the command line
Let me help you figure things out on your own.
At the command line type VLIDE [enter]
Expand the FILE menu, select New File
Paste this routine in the <Untitled-1> window.
With your cursor highlight the "rtos" function, then press Ctrl-Shift-A
The Apropos window appears. In that window Highlight RTOS and click on the Question Mark button
The Help window will appear.
HTH
« Last Edit: November 12, 2007, 11:08:14 AM by CAB »
