kentium3k -
When I am making my own drawings and adding piping systems then I will use a layer for each system because at some point I will be taking each system and moving it into its existing master drawing. So if I have the nitrogen piping on the same layer as oxygen, HF acid, etc. it makes it much harder to grab each system and move to their own drawings.
That make perfect sense to me. But, I am also somewhat annoyed with the previously mentioned layers with names make that no sense, other than to the one that created them.
Then there are the layers that you absolutely cannot purge. Even after exploding everything.
I also don't understand the common practive of having room names, room numbers & the box that surrounds them on 3 DIFFERENT layers. I cannot put these on one layer for my dwg, because if I explode them, they turn to text that says 'name' & 'number'. - I understand what these are, but don't understand why they need to be on different layers.
Uh oh, I'm starting to rant, and that was NOT my intent by posting this question.
Honestly, I was only curious about why so many layers.I am
VERY greatful for any floor plans that I get from others, and tell them each time they send them to me.
Thanks for all of the responses, this has been educational and somewhat entertaining.
craigr
