Author Topic: My first post here - How to fix Mline Mlstyle  (Read 1904 times)
jaydee
« on: December 03, 2009, 02:48:33 AM »
Hi.
My first posting in theswamp.
Could someone pointing me to the right direction or help me out how to fix a MLINE MLSTYLE problems.
- Mlstyle element consisted of parallel lines with linetype bylayer.
- The centre of the mline with linetype named "shapeline" which is a custom linetype using a shape file.
- when someone open and save my drawing without the shape file, then the Mlstyle with the linetype "shapeline" will be converted to "continuous" linetype.
- Therefore when i open this same drawing, all the Mlstyle wont display any of the "shapeline".
My question is, is there a way to fix the Mlstyle to replace the "continuous" linetype back to "shapeline" linetype.
Thankyou in advance.
Crank
Re: My first post here - How to fix Mline Mlstyle
« Reply #1 on: December 03, 2009, 07:06:56 AM »
I think you should post a .dwg with a good multiline first, so the tables of the linetype and mlinetype can be investigated.
« Reply #2 on: December 03, 2009, 08:08:09 AM »
have you tried to reload the mlstyles from the definition?
« Reply #3 on: December 03, 2009, 08:37:30 AM »
Glad to hear from you Jaydee.
Do post a sample DWG.
