Tough Questions - Grading Slope and Elevation Calculating Lisp
AutoCAD 2007
I have a quite a few tough questions/requests and I am currently looking for some lisps to solve them. I have been doing some searching online to find the lisps I need, and although I have been able to find some stuff, I still have some things that I can't seem to find exactly what I am looking for. I would like to take the opportunity ahead of time to thank every who views my questions and for any help that is given.
Looking for a couple of lisps for grading a site
1.) For the first lisp I am looking for one that calculates the slope between two points in this order...
-click on first point
-if the first point was clicked on a contour line that has a "Z" elevation set to it use it - IF NOT (Z elevation of line set to zero) - ask to manually give elevation for that first point
-click on second point
-if the second point was clicked on a contour line that has a "Z" elevation set use it - IF NOT (Z elevation of line set to zero) - ask to manually give elevation for that second point
-have the lisp take the distance between the two points with the elevations given and calculate the slope between the two points (giving you the slope % or decimal or both would be great)
2.) The next lisp I am looking for is one that produces an elevation of the second point in this order...
-enter the elevation of the first point
-enter the slope in %
Example: 1% which will equal a increase slope, adding the increase in elevation to the first point elevation given
-1% which will equal a decrease slope, subtracting the decrease in elevation from the first point elevation given
-have the lisp calculate the elevation of the second point you clicked
3.) Last but not least I am looking for an interpolation lisp that has steps in this order...
-enter elevation of the first point
-enter elevation of the second point
-have the lisp place a letter "x" based on current text style (with a middle center insertion point at its center) at all the whole numbers between the two points
For example if the first point = elevation 120.50 and the second point = elevation 123.00. The lisp will place an "X" between the two points clicked at elevation 121.00 and at 122.00
Who is up for the challenge?
