Author Topic: Math problem - calculating a volume given points  (Read 6131 times)
VovKa
  • Ukraine
Re: Math problem - calculating a volume given points
« Reply #15 on: November 19, 2009, 12:15:00 PM »
Alan, it means that my drawing skills are so bad, that no one is going to believe from the first sight :)
« Last Edit: November 19, 2009, 02:42:23 PM by VovKa »
dgorsman
« Reply #16 on: November 19, 2009, 02:26:43 PM »
Taking the easy part first - volume of the middle chunk.
Vmiddle = A * L, where
L = min (PFz PGz PHz) - max ( PAz PBz PCz)
Area is bit trickier, we need to create a set of intermediary points.  Using the three points at the lower end we get
Iz = max ( PAz PBz PCz)
PAM = (PAx, PAy, Iz)
PBM = (PBx, PBy, Iz)
PCM = (PCx, PCy, Iz)
Area of a triangle is 0.5 * base * perpendicular height.  We can use any of the three sides as the base, but the height needs to be trig'd.  So using line PAM PBM as the base, the distance d is perpendicular from line PAM PBM to PCM:
A = 0.5 * | PAM PBM | * ( | PBM PCM | * sin PAM-PBM-PCM )
( LISP to come next week, unless somebody is feeling industrious )
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
VovKa
  • Ukraine
« Reply #17 on: November 20, 2009, 12:25:13 PM »
my 3d experience equals to zero, so i had to spend a couple of hours restudying stereometry
here's what i got so far
(defun vk_GetArea (CoordsList)
  (abs
    (/ (apply '+
     (mapcar (function
(lambda (p1 p2)
 (* (+ (car p1) (car p2)) (- (cadr p1) (cadr p2)))
     CoordsList
     (cons (last CoordsList) CoordsList)
       2.0
(defun vk_IsPointOnLine (p1 p2 p / r)
  (equal (+ (distance p p1) (distance p p2))
(distance p1 p2)
1e-8
(defun vk_GetOrt (v / k)
  (setq k (/ 1.0 (distance '(0 0 0) v)))
  (mapcar (function (lambda (c) (* c k))) v)
(defun vk_GetCrossProduct (v1 v2)
  (list (- (* (cadr v1) (caddr v2)) (* (caddr v1) (cadr v2)))
(- (* (caddr v1) (car v2)) (* (car v1) (caddr v2)))
(- (* (car v1) (cadr v2)) (* (cadr v1) (car v2)))
(defun vk_Get3pNormal (p1 p2 p3 /)
;;;  (c:cal "nor ('p1','p2','p3')")
  (vk_GetOrt
    (vk_GetCrossProduct (mapcar '- p1 p2) (mapcar '- p3 p2))
(defun vk_GetPlaneNormal (PlaneLst / p1 p2 p3)
  (setq p1 (car PlaneLst)
p2 (cadr PlaneLst)
PlaneLst (cddr PlaneLst)
  (while (and (setq p3 (car PlaneLst)) (vk_IsPointOnLine p1 p3 p2))
    (setq PlaneLst (cdr PlaneLst))
  (if p3
    (vk_Get3pNormal p1 p2 p3)
(defun vk_TransPlane (PlaneLst N / pn)
  (setq pn (vk_GetPlaneNormal PlaneLst))
  (mapcar (function (lambda (c) (trans c N pn))) PlaneLst)
(defun vk_GetPointToPlaneDist (p PlaneLst / n)
;;;(c:cal "dpp ('p','p1','p2','p3')")
  (setq n (vk_GetPlaneNormal PlaneLst))
  (abs (- (last (trans (car PlaneLst) '(0 0 1) n))
 (last (trans p '(0 0 1) n))
(defun vk_GetFrustumVolume (BottomLst TopLst)
  ((lambda (s1 s2)
     (/ (* (vk_GetPointToPlaneDist (car TopLst) BottomLst)
  (+ s1 s2 (sqrt (* s1 s2)))
3.0
    (vk_GetArea (vk_TransPlane BottomLst '(0 0 1)))
    (if (cdr TopLst)
      (vk_GetArea (vk_TransPlane TopLst '(0 0 1)))
      0.0
(defun vk_GetPyramidVolume (BaseLst apex)
  (vk_GetFrustumVolume BaseLst (list apex))
(defun vk_GetPrismVolume (BottomLst TopLst)
  (vk_GetFrustumVolume BottomLst TopLst)
all functions are meant to be generic
still to be done: split the solid into three frustums. one of them will be a prism and two other - pyramids
« Reply #18 on: November 20, 2009, 06:59:37 PM »
This assumes that the body is vertical.
Is this a given for your problem.
Regards
dgorsman
« Reply #19 on: November 23, 2009, 05:09:48 PM »
Regards
Yup.  From the first post, PAxy = PFxy, PBxy = PGxy, and PCxy = PDxy.  If this wasn't a case, then an arbitrary coordinate system could be set up to make it so, with all initial points converted to that system.
try {GreatPower;}
   finally
      {MasterBasics;}
dgorsman
« Reply #20 on: December 01, 2009, 02:59:29 PM »
Never fails - I get started on something and three other things pop up which need doing *now*.
;; math_lib:volumeOfSolid4
;; arguments: plane1 - list of three points (as list) describing the lower
;;   plane
;;   plane2 - list of three points (as list) describing the upper
;;   plane
;; return value: real with shape volume
;; comments: calculates the volume of shape defined by two triangular planes.
;; This function is intented to work in consistent metric units i.e.
;; if the drawing is in millimeters the volume will be in mm^3.
(defun math_lib:volumeOfSolid4 ( plane1
                                       plane2 / return_volume
                                      vol_middle vol_lower vol_upper
                                      PA PB PC PF PG PH
                                      Iz1 Iz2
                                      PAM PBM PCM
                                      area_section )
;; Local defun: x value of a coordinate
   (defun |x| ( input ) (car input))
;; Local defun: y value of a coordinate
   (defun |y| ( input ) (cadr input))
;; Local defun: z value of a coordinate
   (defun |z| ( input ) (caddr input))
;; Local defun: angle from three points, as interior and exterior values
   (defun get< ( pt1 vertex pt2 / return_angle angle1 angle2 )
            (setq return_angle (- (angle vertex pt1) (angle vertex pt2)))
            0
      (setq return_angle (+ (* pi 2) return_angle))
      (list
         (max (- (* pi 2) return_angle) return_angle)
         (min (- (* pi 2) return_angle) return_angle)
;; Split up the arguments into the lower plane coordinates (PA PB PC) and the
;; upper plane coordinates (PF PG PH)
   (setq
      PA (car plane1)
      PB (cadr plane1)
      PC (caddr plane1)
   (setq
      PF (car plane2)
      PG (cadr plane2)
      PH (caddr plane2)
;; We break the solid into three parts - a triangular solid with parallel end
;; faces and two pyramids.
;; Step 1: getting the volume of the triangular solid
;; Construct a plane based on the max z of the lower plane
   (setq Iz1 (max (|z| PA) (|z| PB) (|z| PC)))
   (setq PAM (list (|x| PA) (|y| PA) Iz1))
   (setq PBM (list (|x| PB) (|y| PB) Iz1))
   (setq PCM (list (|x| PC) (|y| PC) Iz1))
;; Get the area of the end planes, using 0.5 * base * height, or
;; 0.5 * |PAM PBM| * (|PBM PCM| * sin < PAM-PBM-PCM)
   (setq
      area_section
           0.5
           (distance PAM PBM)
           (distance PBM PCM)
           (sin (cadr (get< PAM PBM PCM)))
;; Calculate the volume using the distance from the max z of the lower plane
;; and the min z of the upper plane
   (setq Iz2 (min (|z| PF) (|z| PG) (|z| PH)))
   (setq
      vol_middle
           area_section
           (distance
              PAM
              (list (|x| PF) (|y| PF) Iz2)
;; Step 2: get the volume of the lower pyramid
;; This is just a placeholder for the moment
   (setq vol_lower 0)
;; Step 2: get the volume of the upper pyramid
   (setq vol_upper 0)
   (+ vol_middle vol_lower vol_upper)
Apologies for the gibbled formatting - I'm a little tight on time.   :oops:
try {GreatPower;}
   finally
      {MasterBasics;}
