Author Topic: How to avoid exiting while an error occurs?  (Read 1663 times)
litss
« on: November 17, 2009, 10:37:37 AM »
I am trying some code from others. But there is one line that just can't run properly in my thinkpad laptop. here is it
(vlax-create-object "Scripting.FileSystemObject")
I don't want the routine stop at that point, then I put an error checking for this line, but it fails.
(vl-catch-all-error-p (vlax-create-object "Scripting.FileSystemObject"))
Needs help. How can I write this error-check?
thx!
Re: How to avoid exiting while an error occurs?
« Reply #1 on: November 17, 2009, 10:48:44 AM »
Try this:
(vl-catch-all-apply 'vlax-create-object (list "Scripting.FileSystemObject"))
or this:
(setq err (vl-catch-all-apply 'vlax-create-object (list "Scripting.FileSystemObject")) )
(if (vl-catch-all-error-p err)
  (alert "Failed")
litss
« Reply #2 on: November 18, 2009, 10:29:33 AM »
thx! CAB
It works:)
I've just read the help file, it seems that the vl-catch-all-apply and vl-catch-all-error-p should be used together, right?
